    PA 2007 installs not retaining previous settings
    36 Posts 10 Posters 32.5k Views
      davidsplash @amh209
      this is still not fixed and it means i have to change the toobars and settings every install.
      • A Offline
        amh209 @davidsplash
        Did they release beta 9 and I miss it?
          spwolf conexware @amh209
          @amh209:
          no, just nobody is reading what I write anymore
            try now guys…
            NormandieN 1 Reply Last reply Reply Quote 0
            • A Offline
              amh209 @By-Tor
              It worked for me! :D :D :D
              • NormandieN Offline
                Normandie @spwolf
                try now guys…
                Thanks spwolf, works for me!!! :D
                Have a nice day,
                Normandie
                • ? This user is from outside of this forum
                  Guest
                  Fixed in PowerArchiver 2007 10.00.28 Beta 9
                    TBGBe @Guest
                    Just for fun err… testing, I uninstalled PA beta, rebooted, then installed PA 2006 and entered registration code.
                    Then I tried “upgrading” to Beta 9…
                    Of course, registration is “lost” - but the timer showed
                    Days Used : 16 (Out of 30)
                    Not sure where this came from, but I like it - two weeks to get the new/free code seems eminently fair.
                    Maybe in this specifc case (upgrade of registered version) there should be a text stating that new codes are needed and where to get them?
                    Even the skin was preserved when switching to classic view :cool:
                    The only other setting not preserved were the shell extensions - not really surprising.
                      spwolf conexware @TBGBe
                      @TBGBe:
                      If you just installed PA 2007, it would be at 0. But uninstalling PA 2007 will not reset it to 0 :-)
                        TBGBe @spwolf
                        As I said I don’t think there is a problem it is just that
                        if I uninstall PA 2007 and install PA 2006 it says:
                        Days 842 (out of 30) - Expired :D
                        And I was used to seeing that - earlier 2007 BETAs also told me that.
                        Now if I uninstall PA 2007(B9) and install PA 2007(B9) it says:
                        Days 16 (out of 30)
                        That’s why I mentioned it.
                        Maybe the 16 days used is just counted from installation of PA 2007 Beta 8 - but as I did enter register code for that I am not sure where it counts from :confused:
                          @TBGBe:
                          Days 16 (out of 30)
                          We changed the the date for counting PA 2007 in one of the beta’s, so it counts from then… I am not sure exactly which one was it…
                            TBGBe @spwolf
                            Well I was just wondering if a first time upgrade from PA2006 to PA2007 will reset the counter to 0 for PA2007?
                            There is another “problem” however.
                            When upgrading from PA 2006 to PA 2007, the entry in Add/Remove programs for PA 2006 is not removed.
                            So I now have two entries.
                            If I now click to remove PA 2006 - it actually removes the installed PowerArchiver but leaves the entry for PA 2007 in Add/Remove programs :confused:
                              You should uninstall PA 2007 and then PA 2006, and then install PA 2007.
                              As to the counter, it is relative to when it is installed first on your system, which is why it shows you 16 days… to person who installs it today, it will be 0.
                                TBGBe @spwolf
                                So “upgrading” from PA2006 to PA2007 is not going to be possible - only clean install (with loss of settings).
                                  @TBGBe:
                                  unless you want to leave PA 2006 entry in Control Panel…. If thats fine, then upgrading is possible.
                                    davidsplash @amh209
                                    fixed in latest beta
