    PA 2007 installs not retaining previous settings
    36 Posts 10 Posters 31.4k Views
    • W Offline
      welhaux
      All PA 2007 betas I’ve installed clobber the old install. This means I have to both reenter the registration code and reconfigure all my settings. Even now, going from beta 4 to beta 5 required that I once again redo everything.
      I most certainly hope this will be fixed.
      • RJWaringR Offline
        RJWaring
        Totaly agree with you, this has also happend to me on every upgrade and it does become slight frustrating more so when you have to re configuire all your settings over and over again.
        This is why in one of my posts I asked for a “Save Configuiration” button that extracts your prefered settings to a file which you can upload on the next upgrade thus stoping you from having to re apply everything all over again.
        For security reasons you can understand why you need to re-enter your serial number but for beta’s i wouldnt say it was needed. more so on full releases.
          spwolf conexware @RJWaring
          @Sir:
          its an bug, so you shouldnt need to re-enter everything every time :-)
          • RJWaringR Offline
            RJWaring @spwolf
            Cheers for that! We will let you off :0) this is what you get being beta testers!
            • NormandieN Offline
              Normandie
              @welhaux:
              Still not fixed in Beta 6, I had to enter all my info and redo my configuration again.
              Thanks,
              Normandie
              • A Offline
                amh209 @Normandie
                I’m also noticing the same problem.
                  it has been fixed in beta 6, problem is that it depends on previous installation you did… so in next version it will work fine for you guys…
                  NormandieN 1 Reply Last reply Reply Quote 0
                    Normandie @spwolf
                    Great, thanks alot & have a good day.
                    Normandie
                      DJMatty
                      Hi
                      I have just installed beta 6 of PA 2007, and it asks me to register again (enter my name and code) every time I run it. Is this the same problem as the one you guys have described?
                      Just installed it on a new install of XP without upgrading, and I also uninstalled 2007 and installed 2006, entered my details and code, checked it worked ok, then upgraded to 2007 and the same thing happened.
                      Is this fixed with the fix for the settings changing, or have I found a new bug?
                      Cheers
                      Matt
                        spwolf conexware @DJMatty
                        @DJMatty:
                        Hi
                        Cheers
                        Matt
                        you need to visit your account and get codes for PA 2007, as they are different from PA 2006 codes.
                          DJMatty
                          Hi spwolf
                          Thanks for that, got new codes and it works fine :)
                          It’s not obvious that new codes was what was wrong when it happens though, can it check and tell the user that they need new codes?
                          Matt
                            @DJMatty:
                            Hi spwolf
                            Matt
                            there is no way for us to do that right now… which is why it is written on the website several times :-)
                              davidsplash @spwolf
                              In beta 7 i have the same problem. I reformated my hard drive and installed beta 6 and then i installed beta 7 and i have to renter my settings again. looks like pa is over writing the settings thats what my installed monitor is saying. When will this be fixed i have a windows 2000 computer. its an annoying part of upgradeing pa with every beta
                              • C Offline
                                Cristian @davidsplash
                                I can confirm this too, all my settings for the previous beta (including the serial number) were lost during the upgrade to the latest beta.
                                It would be nice if the installer could remember the settings (shell extensions, folders etc.) during the update.
                                • A Offline
                                  amh209 @Cristian
                                  Not fix in 7, still had to enter all the reg info.
                                  B D 3 Replies Last reply Reply Quote 0
                                  • B Offline
                                    By-Tor @amh209
                                    Confirmed here too with beta 7. It would be nice to export settings just so we wouldn’t have to go through this - but, that’s a different issue. ;)
                                    spwolfS A 2 Replies Last reply Reply Quote 0
                                      spwolf conexware @By-Tor
                                      @By-Tor:
                                      we found another bug… it will be now fixed for… b9 :-).
                                      thank you guys - you can always export via regedit.exe and then just execute the .reg file after installation…
                                      • W Offline
                                        welhaux
                                        As others have stated, this is definitely NOT FIXED in Beta 7
                                        • RJWaringR Offline
                                          RJWaring
                                          Ditto!
                                          I have actually designed my own regkey that will upload my Username, Serial aswell as my old prefered settings in order to save time as we are now in Beta 7 and still the settings don’t seem to save after an upgrade.
                                          In some new software programs when upgrading or uninstalling you have the option to keep or delete your current registry settings I would suggest that this might be an idea PA2008 Have or maybe a later release of 2007 Final.
                                            @Sir:
                                            Ditto!
                                            again, it is an bug :-). It will still be reset in B8, but then it will work fine in B9 or final, whatever comes sooner :-).
