    PA2007 Shell Extentions V2
    3 Posts 3 Posters 3.4k Views
    • RJWaringR Offline
      RJWaring
      PA Crew,
      As shown in the attached image, can you please allow us to move the shell names within the configuiration screen thus allows a user to move up their most used and down the ones they dont.
      PA Only allows you to drag across the submenus and puts it in its own format.
      Also, If possible can we have the ability to create our own submenu? eg PowerArchiver-“Security”-Encrypt-Decrypt-…
      PowerArchiver-“Tools”-Compress-Decompress-Test-FTP
      PowerArchiver-“Communications”-FTP-EMAIL
      Also can you get rid of the “2007” on the submenu in the shell extention when right clicking it hogs up space and makes it too long. seeing that you dont call your application icon Powerarchiver 2007! and just powerarchiver
      • R Offline
        rev23dev
        @Sir:
        PA Crew,
        I’m definitely for that.
          that would be an wish for one of the future main releases…
