    Filename is too long
    12 Posts 3 Posters 8.6k Views
    • guidoG Offline
      guido
      See image.
      The filename should not be wider that the progressbar.
      Guido
      Windows 11 Pro ENU x64
      Intel Core I7
      32 GB RAM
        :-) thanks
        • guidoG Offline
          guido
          not fixed in b5
          Guido
          Intel Core I7
          32 GB RAM
          • guidoG Offline
            guido
            not fixed in b6
            Guido
            Intel Core I7
            32 GB RAM
              ivan conexware @guido
              Hm,
              This field has same size as ProgressBar and starts at same position so I cannot reproduce this. Can you send a screenshot from latest beta?
              • guidoG Offline
                guido @ivan
                See image.
                Guido
                Intel Core I7
                32 GB RAM
                  does the first part have many uppercase letters?
                  • guidoG Offline
                    guido
                    No
                    Guido
                    Intel Core I7
                    32 GB RAM
                    • guidoG Offline
                      guido @guido
                      Not fixed in b1.
                      Guido
                      Intel Core I7
                      32 GB RAM
                        The issue should be fixed in Beta 2.
                          This should be fixed in latest version:
                          http://www.powerarchiver.com/test/release10/powarc1010.exe
                          Please let us know…
                          • guidoG Offline
                            guido
                            FI .10
                            Guido
                            Intel Core I7
                            32 GB RAM
