    Version 10 Beta 2 Scan Problem
    8 Posts 3 Posters 7.4k Views
    • NormandieN Offline
      Normandie
      I have installed the version 10 beta 2 and cannot get the virus scan feature to work. In version 9.63 I entered the scan program as:
      C:\Program Files\Grisoft\AVG7\avgw.exe
      and then under “paramaters” I entered:
      /SE “C:\Documents and Settings\my user name\Local Settings\PowerArchiver Temp Files”
      Of course I set up the temp directory and everything scanned and worked great. Now when I do this in version 10 Beta 2 the scan seems to take place, but shows 0 objects scanned and 0 errors. If I revert to 9.63 the above lines work. Any help would be appreciated.
      Thanks,
      Normandie
        instead of support response :-).
        Try without folders included into the setting. PA should automatically read your temp folder from other settings.
        So under parameters:
        /SE
        Let me know how it works.
        NormandieN 1 Reply Last reply Reply Quote 0
          Normandie @spwolf
          /SE
          spwolf,
          Sorry I should have listed the other things I have tried, they are:
          /SE
          /SE%1
          /SE%D
          None of them worked at all. thanks for trying. I guess we will have to wait for a fix.
          Have a good day,
          Normandie
            Normandie @Normandie
            Just downloaded Beta 3 and this bug didn’t get crushed ;)
            Thanks,
            Normandie
              spwolf conexware @Normandie
              @Normandie:
              Thanks,
              Normandie
              we will check it out for b4.
                Normandie @spwolf
                spwolf,
                Thanks, it is not a big bug, just a tiny little one, no rush, I can live without it for now.
                Have a good day,
                Normandie
                  ivan conexware @Normandie
                  What can be fixed it must be fixed;)
                    Normandie @ivan
                    This bug is still not fixed in Beta 4. I think I may go back to 9.64 until this is fixed, it is becoming more needed.
                    Thanks,
                    Normandie
