    LHA problems
    9 Posts 3 Posters 6.8k Views
      Mameluke
      Found another bug O_O.
      Works when compressing animated GIF files with LHA.
      Tested on 3 different gif files.
      1. Create an LHA archive with the animated GIF file in it.
      2. Hit test.
      3. CRC error
      4. You can force an extract and still get the file to extract with the CRC error and the file works however the size is slightly off :(
      Didn’t have the time to test other file types but am guessing this is not a good thing when you need somethign to be intact.
      Can anyone else confirm this?
      Mame
      Update:
      Put the files in a text editor for comparison purposes:
      A whole bunch of crap was added to the bad CRC file at the end of it. File runs ok but it is bigger in size than the original.
        Beta 2? Thanks
          Mameluke @spwolf
          Yes
          Version 10.00.14
          Mame
              ivan conexware @spwolf
              I am not sure will it be fixed for Beta 3, but I will investigate this bug and inform you with updates.
                Mameluke @ivan
                I noticed that this happened when I put just one animated gif into the file.
                If i put the gif and another file it didn’t happen. Hmmmm ….
                Mame
                  ivan conexware
                  OK - I have reproduced the problem - working on a resolve. I will update the thread when I have something…
                    Mameluke @ivan
                    Excellent :)
                    Thank You
                    Mame
                      Mameluke @Mameluke
                      Update: Problem still present in Beta 3.
                      Mame
