Space on PAS Queue
The space on the left side of the queue is smaller than size on the right.
Guido
And shouldn’t the text be:
Use queue system when compressing or extracting files
Guido
well, you can use it for both :-).
Thanks for the size… -
The issue should be fixed in Beta 3.
NF in b3.
Guido
NFI B5
Guido
The issue should be fixed in Beta 6.
Same applies to the configuration screen if you look at the attached image the left, right,top and bottom are all different lengths
FI b6
Guido
