    Wrong wording on dialog
    3 Posts 3 Posters 4.0k Views
      davidsplash
      if you select a file within pa and then use the context menus from within pa to virus scan it tels you to go to program loactions on the configuration menu when it should say folders
        actually it is correct, however in the config we changed locations and folders by mistake…
          ivan conexware @spwolf
          Location and Folders will be swaped in next release.
          Ivan
