    Shell extensions
    5 Posts 3 Posters 5.1k Views
      davidsplash
      problams getting shell extenions under pa2007 shows them in a list on the normal extensions not under the pa 2007
        Under Options / Configuration / Shell Extensions
        you can add the extensions either to the menu or in PowerArchiver sub-menu.
          davidsplash @TBGBe
          thanks fixed
            davidsplash @davidsplash
            problem with submenu compress to option.
            when u click on it it opens up if you click on the x in the right hand corner a box comes up saying compressing files nothing happens though thankfully. You just have to cancel this window either by the x in the right had corner or by pressing cancel. Why should this be appearing if you x from prevous screen. Sure that would cancel any more windows opening up.
              ivan conexware @davidsplash
              The last issue should be fixed in Beta3.
