    Plugins
    6 Posts 4 Posters 5.1k Views
      davidsplash
      what plugins are avlaiable for the nw 2007 version
        more info on the plugins will be given in future beta’s….
        • RJWaringR Offline
          RJWaring
          Plugins can be anything from Automatic Tasks or Misc Software support?
          Are both these areas going to be supported or are we looking at something different.
            ivan conexware @RJWaring
            Plugins will only support extracting of custom formats, not supported by PowerArchiver. Plugins are fully compatible with TotalCommander plugin file format.
            For future version we plan to add support for compressing archives via plugins to formats not supported by PowerArchiver.
            • RJWaringR Offline
              RJWaring @ivan
              Sounds Good! I’m looking forward to this new feature now!
              Does this mean PA will develop a Plugin Creator for PA plugins? and am I correct in assuming we will have a plugin page in the New PowerArchiver 2007 Website where we can exchange ideas and plugins created?
                ideas you can exchange in forums, of course, and there will be plugin listing page… Not sure about anything else, as that is more left towards the final version of PA 2007.
