Navigation
    • Right-click encrypt not working
      Powerarchiver 2022
      Right-click and select Encrypt on a folder does not work.
      Although it says it encrypts, there is no encrypted file in the destination folder.
    • File Explorer Shell Extension crash on Junction
      Re: Explorer.exe Crash on right click
      This appears to be happening again with the Power Archiver 2022 shell extensions.
      When I have Use Explorer Shell Extensions enabled in Power Archiver Configuration and right-click on c:\Users\username\Start Menu, (hidden Junction file), File Explorer crashes.
      I have version 21.00.15 (03/2022) 64-bit installed in Windows 10 Version 21H2 (Build 19044.1826).
    • Latest version and online update
      P
      The online update feature within the program suggests there is a later version than the ‘.17’ available on the web site. But clicking either download or update just reinstalls version .17.
      Either there isn’t an update OR
      the “download” and 'update" links should be repaired.
    • Cannot login
      P
      Hi Dear,
      Cannot login and request resend license code for my fd
    • PowerArchiver Purchase
      When you click on the Buy Now link, you come across four tabs - Home or Work, Enterprise Unlimited, Educational Discount, & Gift Discount.
      What is the difference between a licence purchased via Gift Discount and a Home/Work licence?
      Also, how can I renew the PowerArchiver Select plan a year after the purchase? Will it remind me automatically?
      Best,
    • Power Archiver Starter - CPU and power overhead
      PA_Fan
      I’m running PA 21.00.17 64-bit on a 64-bit i7 desktop with W10 Pro, latest version. This 32gb of installed RAM.
      As I use the PA pbs system for a number of scheduled archiving operations throughout the day, PA Starter is set to load and run at system startup.
      In the course of trying to identify some causes of slowness and bottlenecks in other processes, I notice that PA Starter (PAS) always runs at between 11% and 15% of CPU (see screenshot), usually at about 12-13%. This is by far the highest demanding process on the system, as shown by Task Manager. In Performance Monitor, PAS Average CPU is 8.32, with every other process at less that 1 i.e. in decimal places only.
      Task Manager also shows PAS Power Usage as “Very High”, and is the only process shown thus.
      I have looked again at the information about PAS at https://wiki.powerarchiver.com/en:help:details:powerarchiver_starter, which was last modified in 2016. The article states a low memory usage for PAS of 784k, which is fair enough, but it is the large CPU overhead which is of concern.
      It is of course possible to change the PAS priority, but this has no effect on CPU overhead.
      However, is it possible to change PAS, which is required only at intervals to initiate PA scheduled tasks, from consuming so much system resource for every moment of the day?
    • Slow multipart RAR extraction
      I’m experiencing very slow extraction speed of multipart RAR files. For the first part the extraction is super fast but when PA reaches the part2.rar the extraction from there on gets super slow. PA needed for a 6,3 GB multipart archive 30 minutes to extract. I tested then with another program and it just took 70 seconds. I had this slow extraction speed with PA for quite a long time and I always thought that is maybe because of a high compression rate that the extraction would take longer. But it seems that only PA gets that slow.
      I have lots of multipart archives that are 10+ GB and with PA it would be really time consuming. Is there any solution to this?
    • Action Move - Not Working in Tools - Batch Archive
      G
      Hi. The “Move” Action seems to be Not Working when used in the Tool – Batch Archive.
      Using the Options – Configuration – Compression Profiles ---- I created a Profile with the Action of Move. Also set were Zip, and Method Deflate.
      When I use the Tool - Batch Archive – It appears to me that the Action Move does not Move the compressed files (basically add to zip, and delete the added file from original location on the same disk). Zip file(s) are created and look ok.
      Typically I on the Batch Archive process – I have selected options to use a Profile with the Move Action.
      File’s Current Folder Group files from same folder into same archive Add subfolders to separate archives
      My PowerArchiver version is 21.00.17 .
      Can you reproduce ? – Or do you need additional details or information?
    • Command line
      PowerArchiver Command Line 7 support file greater than 2 Go ?
    • open file manager after extracting from archives...
      P
      i just registered my own copy and i need some help to set it…
      if i set the ‘configuration>shell extension>open folder after extracting’ checkbox, after decompress an archive is opened the file manager on that folder but… if somebody is using a different file manager how to open XYplorer or Directory Opus for example and NOT the MS file manager?
      consider this as a feature request also if not available within the 2022 version
    • Need to find out how to disable "all users" to end UAC elevation prompt on running PA
      Q
      I am looking for a way to stop the UAC elevation prompt when running Powerarchiver. In an old post about PA 2019, someone asked this and got a response to uncheck “all users” at the prompt but I am not seeing where one can do this. It definitely seems like the way to go though as if I click on “More Details” at the prompt I see that it is trying to run “_pautil.exe /paassociate /allusers /my(long binary string)”. Can you let me know? Thanks.
      PS I tried renaming _pautil.exe and this worked, but I don’t know what the consequence of doing this may be so I would like to do this properly, thanks.
    • Question is Ashampoo Zip Pro 4 built by the Powerarchiver team?
      Just a question is Ashampoo zip pro 4 built by Powerrachiver as it is very similar and uses the pae encryption.
    • Transfer PC License to MacBook iOS
      R
      Is it possible to transfer one of my existing PC Licenses to my MacBook?
    • Transfer License
      R
      Re: Transfer PC License to MacBook iOS
      Here is the email…
      On Tue, Jun 7, 2022 at 1:20 PM Rich DiBenedetto rmdibened@gmail.com wrote:
      Greetings,
      Could you assist me with this?
      Can I use my current licenses with MacOS?
      If not, can I transfer a license to MacOS?
      Cheers and Have a Great Day,
      Rich
      On Wed, Dec 9, 2020 at 6:35 AM ConeXware, Inc. ordering@conexware.com wrote:
      Dear Richard DiBenedetto,
      Thank you for supporting PowerArchiver! Please find your activation and registration codes below.
      *** Online Activation ***
      PowerArchiver Select for PowerArchiver Toolbox English - LIFETIME
      is valid until - not limited.
      E-Mail: RMDibened@gmail.com
      Activation Code: ***
    • Does PA supports Intel's zlib?
      G
      There would be many of us with Intel Processors.
      and they have their own optimized zlib algorithm, which can result in more efficiency if used combined with their hardware processor.
      Reference:
      https://www.intel.com/content/dam/www/public/us/en/documents/white-papers/zlib-compression-whitepaper-copy.pdf
      Can we get the same Functionality Under Hardware Acceleration Feature?
      Zlib is not the only feature that intel has included with their processor, there’s many, which if combined can result in efficient and better compression ratios.
    • GUI: Issue with buttons
      guido
      Right buttons are not visible
    • PA 2.00.01 macOS - stuck with no support
      F
      Greetings, new customer searching for help and/or refund…
    • Windows 10 File Explorer crashing context menu on Junction
      With PowerArchiver context menu enabled, it is crashing Windows 10 File Explorer when right-clicking on the Default User junction in C:\Users. Had 2021 installed, updated to today’s 2022, still getting same crash. Must have Hidden files and folders set to Show, and Hide protected operating system files cleared in File Explorer Options|View.
      Windows 10 Enterprise Version 21H2 (OS Build 19044.1708) (64-bit)
      PowerArchiver 2022 Version: 21.00.15 (03/2022) 64-bit
      Licensed:
      PowerArchiver Toolbox Edition Personal English
      Disabling PowerArchiver context menu using Autoruns: on the Explorer tab, uncheck PowerArchiver64 under HKLM\Software\Classes\Folders\ShellEx\ContextMenuHandlers and the crash does not happen.
    • Conexware update
      OS: W10 21H2 19044.1645
      Best regards
      Wilfrid
      PS: Keep building such good software
    Multi-Monitor and Power Archiver
    6559
    • C
      CuoioBar last edited by
      I just installed the demo of PowerArchiver (friend’s recommendation). Been using a freeware (7Zip) and thought I would try this one. Looks and works great, considering purchasing, but have one problem with multi monitor. PA won’t stay in the second monitor, if you close PA in the second monitor, it will start in the second monitor, but if you drag a file out of an archive or use the extract command, the progress bar opens and PA then reappears on the first monitor. Is there a way within PA to keep it only on the second monitor?
      • spwolf
        @CuoioBar:
        there is no such option right now for sure. We will take a look to see what we can do about it in one of the future updates.
        Of course, base your purchasing decision on the fact that it is not working to your liking right now :-).
        • K
          Kippesoep last edited by
          Add my vote to a fix for this. PA is one of the most useful programs I ever bought. This minor niggle does irritate me on a daily basis, though.
          • RJWaring
            RJWaring last edited by
            I have experienced this same problem with other applications such as Microsoft Access, Excel, Word, and adobé 8 Pro.
            It’s a common issue that effects multiple applications, and I agree that it is slightly frustrating.
            But on a more realistic side. How many users have dual screen and depend on such an application to co-inside with split screen requirements.
            3 so far. and I too would like a fix for this minor problem.
            • K
              Kippesoep @RJWaring last edited by
              @Sir:
              It’s hardly a major problem, of course, but the number of dual screen users is rising (in fact, over 75% of the people I know now have dual screen setups). And of course, for every person that reports the bug or posts on this forum, there’s 10 others that experience it but keep quiet.
              3 votes and counting :)
              • spwolf
                spwolf conexware @Kippesoep last edited by
                @Kippesoep:
                every problem is major problem and more people report it……
                  mwb1100 @spwolf last edited by
                  Add my vote for fixing this.
