    PowerArchiver going crazy
    4 Posts 3 Posters 4.9k Views
    • Daniel TMD Offline
      Daniel TM
      Hi guys, I’m new to the forum.
      I was extracting files from a .iso file and the label under the second progressbar said ‘250% completed’.
      I took a screenshot, cropped the window, and censored the name of the file that was being extracted. The image is attached to this post.
        is the file extracted fine? Whats the size of it?
        Daniel TMD 1 Reply Last reply Reply Quote 0
          Daniel TM @spwolf
          Before I reported this bug I found another solution so I deleted the .iso file, but the file was perfect and it was in a matter of gigs, about 3 to 4 GB. Sorry if I can’t inform you the exact size of the file.
            Shivan
            spwolf, you should do a check every time PA updates it’s progress: if progress > 100, progress = 100!
            Simple!!
