    Encryptiion problem - PowerArchiver 9.63.02 hangs
    4 Posts 3 Posters 4.8k Views
    • C Offline
      ChrisSmith
      I am trying to encrypt a 5+ gb RAR archive.
      When I open the archive, then select encrypt, I get prompted to enter and re-enter a password. Then PowerArchive goes away and never comes back.
      Same thing happens when I try using explorer and right-click on the archive name.
      I am using Windows SP Pro SP2.
      Suggestions ?
        @ChrisSmith:
        Suggestions ?
        Maybe it simply takes too long? I suggest recompressing it to zip aes, that should be faster…
          See also
          http://www.powerarchiver.com/forums/showthread.php?t=1301
          • C Offline
            ChrisSmith @TBGBe
            Patience. I could use an extra large helping of that.
            Thank you.
            :rolleyes:
