    PowerArchiver 9.63 for U3 USB Drives problem
    2 Posts 2 Posters 4.4k Views
      davidsplash
      on looking at my registary after using this version and several other programs that use u3 I found that it left things on my computer that won’t there before. I contacted u3 and they say i need to report it to all people I had the problem with even though it is notrelate to just one software.
      I used the latest pa version but i can’t see how this helps as i even tested other software u3 compatiable and they did the same thing even bran new computer with windows 2000
      thought you sghgould like to know this.
        it helps when you give us details on what exactly is left over… without any info, we cant check it out. thanks.
