    Problems with multivolume+password .rar archives
    15 Posts 7 Posters 20.5k Views
    • L Offline
      loopsy
      Hi
      Using 9.01 I have a problem extracting multivolume RAR archives, which are additionally password protected.
      When I open the RAR with power archiver, the password-prompt pops up and I enter
      the password. (which I know is correct)
      Then all the files are displayed in the Power archiver window, so the password is really correct. ;)
      However, I cannot unpack any of the files in the RAR, the extraction folder is generated
      but empty all the time.
      Drag-n-drop does not work either. I can drag the files, but they still are not extracted.
      Any advice ?
      Greetings
      • manuangiM Offline
        manuangi
        I can’t reproduce it, I tried with two rar pw protected archives, and both times PA could extract everything perfectly!
        It might be a problem with that specific archive, huh?
          I cannot reproduce this using WinRar 3.30 to create the archive.
          I tried with both files and filenames protected.
          When I open the RAR with power archiver, the password-prompt pops up and I enter the password.
          So the filenames are encrypted as well - otherwise the filenames are displayed without the password. Were the names displayed with a + after them (indicating password)?
          However, I cannot unpack any of the files in the RAR, the extraction folder is generated but empty all the time.
          Did you get a second password prompt?
          Do you know how the archive was created - was the beta Rar 3.40 used?
          Are the rar files named part1.rar ; part2.rar
          or are they .rar ; .r01 etc?
          • L Offline
            loopsy @TBGBe
            @TBGBe:
            Yes, the filenames have a “+” behind it.
            Yes, I get a second password prompt when I try to drag-n-drop the files out of the
            program-window into another folder.
            Same when I use “extract here” from context menu, nothing happens.
            The filenames are named “part001.rar” etc and “properties” of the archive shows v2.9 :rolleyes:
            • L Offline
              loopsy @loopsy
              By the way, unencrypted archives work ok. Only encrypted do not.
              And its possible to extract the archive with Winrar 3.3, so the files are ok definitely.
                TBGBe @loopsy
                In that case, as neither Manuangi or I can reproduce the problem, it will be difficult for PA Devs to progress without an example archive to examine.
                Does it only happen with the one archive or have you encountered it with different ones?
                Can you provide the archive(s) or a link?
                If not, Could you try 7-Zip utility ( http://www.7-zip.org ) and see if that can extract OK.
                Note: I believe PA uses the rar3.3 unrar.dll so should be compatible.
                  spwolf conexware @TBGBe
                  Hmph, my guess would be wrong password. Your filenames show because they have not been encrypted to start with so they would show anyway. It could be possible that your archive has been corrupted as well, which is a bit harder to find out with encrypted archives.
                  I suggest that you download WinRar and try it… If it works, then it is definetly PA problem but I have tested similar file myself and it does work fine here.
                    davidsplash @spwolf
                    does it only happen with this rar file or is it any created with winrar3.3
                    what is your file name and password. Can you post the archive and password to the forum so we can test it and see what needs doing. I know for a fact that there are limits to the unrar.dll supplied by winrar, and that could be the problem.
                    • L Offline
                      loopsy @davidsplash
                      1. The password was correct and still is…. ;) I would not post otherwise.
                      2. I uploaded a 3 part archive here:
                      http://fukbiaeae.snowkite.net/
                      The password is: test
                      I can decompress using WinRar 3.3, I cannot using PA .
                      Neither with D´n´D, nor via context menu.
                      Bt.w.: I am using WinXP with SP2
                        spwolf conexware @loopsy
                        It quite possibily could be an problem with filenames inside of archive and nothing related to password.
                        We will check it out.
                          ivan conexware @spwolf
                          I couldn’t download those files - server seems not working?
                          • guidoG Offline
                            guido @ivan
                            works fine here
                            Guido
                            Windows 11 Pro ENU x64
                            Intel Core I7
                            32 GB RAM
                              spwolf conexware @guido
                              You can Test new per-release here:
                              http://www.powerarchiver.com/test/release/powarc901.exe
                              It should fix the issue with those characters in the archive.
                              • L Offline
                                loopsy @spwolf
                                Great, works now ! :) Thank you !
                                Is the fixed version already available in german as well ?
                                  @loopsy:
                                  Once we release the official version, it will be.
