    Shell Extension - Archive Converter
    8038
    • C
      Charles Botz
      The shell extension command to convert an archive is broken. :rolleyes:
        you mean it does not add the file to the converter file list? :-)
        • TBGBeT
          TBGBe @spwolf
          Yes I see that too - plus I get a small window with the text “I/O error 103” (Uses PA skin but has no title - just an OK button).
          However, BH file was created
          This was Zip to BH conversion.
          Then tried with “Tar.gz” to “Zip”
          This gives “I/O error 104” and no Zip file is created.
          Note: the error window appears when PA deletes the temp directory.
          C TBGBeT 2 Replies Last reply Reply Quote 0
          • C
            Charles Botz @TBGBe
            Yes, Spwolf, that’s exactly what I’m saying. It does not add the file to the list like it did before. And, it’s annoying.
            Hello Terry! It’s been a while…… :D
            • B
              By-Tor @Charles Botz
              Yes, I’m seeing the same problem too. Convert from the context menu has “Ok” grayed out. I can convert archives that I open with PA normally, but, I use the context menu quite often. :(
                spwolf conexware @By-Tor
                please try latest version from the website…
                • TBGBeT
                  TBGBe @TBGBe
                  @TBGBe:
                  All OK in PA 9.63.02 :D
                  • B
                    By-Tor @TBGBe
                    All is still not well with PA v9.6.3.2. When trying to convert an archive I get the following error on the first try:```
                    Faulting application powerarc.exe, version 9.6.3.2, faulting module powerarc.exe, version 9.6.3.2, fault address 0x00001d62.
                    spwolfS TBGBeT 3 Replies Last reply Reply Quote 0
                      please outline step by step how are you converting it and what you are converting…
                      • TBGBeT
                        TBGBe @By-Tor
                        @By-Tor:
                        All is still not well with PA v9.6.3.2. When trying to convert an archive I get the following error on the first try…
                        On the second try, it is successful.
                        At which point in the process?
                        Convert from what to what?
                        Does the original (from) archive open / extract OK with P.A. ?
                        Enough working disk space (temp directory) ?
                        Edit: Beaten by Spwolf - must type faster…
                        • TBGBeT
                          TBGBe @By-Tor
                          @TBGBe:
                          Ignore - I misread this bit.
                          @By-Tor:
                          • B
                            By-Tor @TBGBe
                            Something must have gone awry with my system when I posted that. Since that time, I’ve been unable to reproduce the error. It may have had something to do with having the U3 version installed previously, but more testing is needed.
