    Shell extensions won´t work on 9.63.1
    53 Posts 9 Posters 50.0k Views
      spwolf conexware @James002
      @James002:
      Well, I changed back to C:\Temp, does not work.
      Here is the reg file (I´ve changed the extension to the txt because this forum doesn´t support reg files).
      exact settings here work.
      Now, where is your PA installed and where is your Win XP installation?
      • J Offline
        James002 @spwolf
        PA - C:\Program Files\PowerArchiver
        WinXP - C:\Windows
        • A Offline
          Amigage @James002
          I also have big problems with the context menu in the last version 9.63.01
          Today I installed the last official version about my existing version.
          Windows XP
          Program Folder: C:\Programme\PowerArchiver
          Temp Folder: C:\Dokumente und Einstellungen\amigage\Lokale Einstellungen\Temp\
          My problems:
          I take some files and drop it over an existing zip file. Normally Powerarchiver did overwrite the existing files. Today the message follows:
          “Fehler beim Schreiben der Datei. Laufwerk voll”
          maybe in english: “Write error. Drive full”
          The existing file is deleted.
          I have 21 GB free on drive.
          So I changed the temp folder to "D:\Temp" and tried it again. If i drop a file over an existing zip file nothing happens. No message, no adding the file. The Zip file still exists.
          The same problem appears if I use the main window. I click new, give a filename, select some files to add and the I get the error message:
          “Fehler beim Schreiben in Datei. Mögliche Ursachen: Datenträger voll, kein Schreibzugriff, Laufwerk nicht bereit, Datenträgerfehler”
          mabe in egnlish: “Error during the writing in file. Possible causes: Data medium fully, no write access, drive assembly not ready, data carrier errors”
          I hope it helps…
          Sorry for my poor english.
          Amigage from Germany
          I attached my registry settings.
          attachment_p_7778_0_pa.txt
            spwolf conexware @Amigage
            thats zip engine issue, check top post of this forum and download the update please.
              @James002:
              ok, I am able to reproduce it now… now we can check it for next update on monday!
              • A Offline
                Amigage @spwolf
                9.63.01 - Hotfix
                Great, it works and the problem is solved :cool:
                B 2 Replies Last reply Reply Quote 0
                • B Offline
                  Banquo @Amigage
                  This post is deleted!
                  • B Offline
                    Banquo @Amigage
                    I installed the hotfix, it did not fix the temp folder problem however. I still get access violations and non working shell extensions if I change the temp location to anything else. I have the program installed to the default location (C:\Program Files\PowerArchiver) and have made no other changes.
                      spwolf conexware @Banquo
                      @Banquo:
                      hotfix solves different problem, this temp folder problem will have to be solved via new version…
                        spwolf conexware @spwolf
                        please try latest version from the website and see if it works…
                        • J Offline
                          James002 @spwolf
                          Hereby, I can confirm that the new version works flawlessly!
                          Thank you for the quick analysis of the problem and the new, fixed version.
                          • K Offline
                            Keith Weisshar @James002
                            Spywolf, can you take the hotfix offline since a new 9.63.02 version has been released.
                              spwolf conexware @Keith Weisshar
                              @Keith:
                              what hotfix?
                              • K Offline
                                Keith Weisshar @spwolf
                                The one for 9.63.01 that replaces the zip engine for NTFS.
                                • T Offline
                                  Tahzis
                                  Good news
                                  • A Offline
                                    Amigage @Tahzis
                                    I have a problem if I want to delete a single file from a zip file. The same error appears: “No space left on volume”. The zip-File was renamed with a temporary name like “G7a01644”
                                    I can rename it to the original filename and the zip file is valid and the selected file is deleted.
                                    Whats wrong?
                                    Best regards
                                    Amigage
                                      @Amigage:
                                      Whats wrong?
                                      Best regards
                                      Amigage
                                      well, what version of PowerArchiver are you using?
                                      • A Offline
                                        Amigage @spwolf
                                        I use Version 9.63.01 with the Hotfix from 24.07.!
                                        DZIPS32.DLL = 6.0.0.5
                                        DUNZIPS32.DLL = 6.0.0.5
                                        Best regards
                                        Amigage
                                          please use the latest version from our website and see if that works.
                                          Other than that, is the zip file read only possibly? Try with some other zip archive (possibly completly new archive) and see if it works.
                                          • A Offline
                                            Amigage @spwolf
                                            Now I installed the latest version, restarted the system.
                                            But the problem is still alive :-(
                                            If I want to delete a file from a zip archive, PA can not rename the zip archive to the original name.
                                            This problem appears also with different zip archives and new archives. The files don’t have the flag “read only”.
                                            Best regards
                                            Amigage
