    Using Explorer Shell Extensions with Folders
    1 Posts 1 Posters 3.5k Views
    • B Offline
      bsledge
      When using the full PowerArchiver program, I have enabled the option to “Use normal relative path” as I add folders, because I always want each folder compressed along with the files within it. This option works as it should, and the results are what I need. However, most of the time, I find it much more convenient to use the Explorer Shell Extensions so that I can simply right-click on a folder name and select “Compress to …”. There does not seem to be an option to use the normal relative path with the shell extensions, only “Save full folder info”, which is not what I need. Is there a way to use the Explorer Shell Extensions and still be able to compress the folders themselves to a zip file along with the files within them?
