    .PAE problem
    • R
      ros
      Hello.
      I’ve a problem with format .pae
      I forget my password of my document file and a can’t
      get to file.
      Please HELP!
      • TBGBeT
        Sorry, but if you cannot remember the password you are out of luck - PAE uses strong encryption.
        http://www.powerarchiver.com/forums/showthread.php?t=1433
          spwolf conexware @TBGBe
          More info can be found here:
          http://www.conexware.com/support/index.php?_m=knowledgebase&_a=viewarticle&kbarticleid=4
          thank you!
          • R
            ros @spwolf
            I’ve made the file 21.1 2006 and that is why I not remember password.
            The file is about my love.She is very beautifull… :)
            I’ve got the file on http://terabite.wz.cz/file/posl_den_21.44.22-06.21.1.2006.pae
            PLEASE HELP!
            THANKS.
            • TBGBeT
              TBGBe @ros
              @ros:
              I’ve made the file 21.1 2006 and that is why I not remember password. …
              PLEASE HELP!
              You have to remember the password (or at least what type of password) you may have used…
              Maybe if you can think WHY you used a password in the first place? what would you use…
              Based on Name - Yours or hers - different spellings
              Date - YMD / DMY…
              Your/Her Feelings - Happy, Sad, Angry etc…
              There is nothing other users (like me) or Conexware employees can do. The password can NOT be “cracked”.
