    Power Archiver Web Update
    7 Posts 4 Posters 6.7k Views
    • K Offline
      Keith Weisshar
      I would like to report an error in web update. It’s showing the following message below:
      Installed Version: 9.61.01
      Latest Version: 9.60.12
      Can you fix the web update server so the latest version shows as 9.61.02 instead of 9.60.12.
        it is not an error, it done for purpose.
        • K Offline
          Keith Weisshar @spwolf
          Does PA need to be updated manually instead of using web update?
          easyzuddinE 1 Reply Last reply Reply Quote 0
          • easyzuddinE Offline
            easyzuddin @Keith Weisshar
            Yo! spwolf, how come you said it done purposely? Can’t understand the meaning…
            • guidoG Offline
              guido @easyzuddin
              Afer everything is fixed, it will become public so everybody gets a notice that there’s a new version.
              There’s no need for everyone to update to a version that has some little glitches.
              Guido
              Windows 11 Pro ENU x64
              Intel Core I7
              32 GB RAM
                spwolf conexware @guido
                @guido:
                Guido
                thank you guido, you know us well :-).
                9.61.03 is out and you all can download it via update.
                • guidoG Offline
                  guido @spwolf
                  Some call it a gift, some call it a curse :D
                  Guido
                  Intel Core I7
                  32 GB RAM
