    Shell extension
    14 Posts 4 Posters 10.9k Views
    • B Offline
      bugfix
      With the last version: 9.61.01 I can’t modify shell extension. Every time that I make a change nothing happens. Also when I disable it if I rightclick on a file I can see the extensions still active. I’ve tried to uninstall and install again but not helped.
      If anyone have an advice…
        Mad_Griffith
        stumbled upon the same bug :(
          spwolf conexware @Mad_Griffith
          did you guys restart your computer after installation?
            Mad_Griffith @spwolf
            I’ve just uninstalled and reinstalled following your advice, spwolf, since it wasn’t specified at all at the end of the setup. But that didn’t help anyway.
            I just forgot to add that, other than I can’t change the shell extension items, I can’t even USE any of them. In fact, clicking on any item doesn’t have the desired effect.
            These problems I have with 9.61 only. With 9.51 everything’s OK. For both versions, I’m speaking of the Italian translation.
              With Italian, it is an known problem with shell extensions - I could not know you are talking about Italian (there is another post about it). Basically it is using english registry keys so it does not work. We will release update tomorrow.
              thank you!
                Thank you very much.
                  Mad_Griffith @Mad_Griffith
                  Hi, when will it be released exactly? I need it so bad!
                    @Mad_Griffith:
                    in few hours should be here… I know, cant live without shell extensions!!! :-).
                      nice, thanks!!
                      what version will it be?
                      • B Offline
                        bugfix @Mad_Griffith
                        @Mad_Griffith:
                        nice, thanks!!
                        I think it has been released.
                        I’ve just downloaded the new version.
                        Is the: 9.61.03 and now the extension problem is solved.
                          Mad_Griffith @bugfix
                          They should update the release date on the download page…
                          curiously, the update manager withing the app doesn’t find anything either…
                          netsurferN 1 Reply Last reply Reply Quote 0
                          • netsurferN Offline
                            netsurfer @Mad_Griffith
                            @Mad_Griffith:
                            I support you. In fact, there is no difference in date stamp and I can only suppose the version was updated!
                            Anyway, that one is version 9.61.03 and it solves the problem.
                            Thank you for support.
                              Mad_Griffith @netsurfer
                              Downloaded & installed, works like a charm. Thanks for the heads-up, netsurfer.
                                thank you, problem with italian shell extensions has been fixed.
                                Closing this thread.
