    Right click: Compress with option
    7073
    • netsurferN
      netsurfer
      Version 9.51.02 Italian
      This is the problem:
      1. I select multiple objects (Directory, files and so on)
      2. I right click choosing “Compress with options”. The dialog box opens…
      3. I change (or not) the proposed name.
      4. I press OK button. The process starts but no zip is created.
      If I repeat the procedure choosing “compress to name_of_proposed_zip” (or similar), the process starts and the zip file is created correctly.
      Thanks for support.
        did you restart computer after installation?
        netsurferN 1 Reply Last reply Reply Quote 0
        • netsurferN
          netsurfer @spwolf
          Yes, more than once!!
          • D
            davidsplash @netsurfer
            what windows are you using
            windows 2000 or xp 98 and what service packs are installed?
            try uninstalling the package reboot computer and try installing again.
            Do you have any other programs on your computer that you have installed that use the context menus?
              spwolf conexware @davidsplash
              we will check it out for 9.6 and see whats up.
              With 9.6 beta, I wasnt able to reproduce it, although nothing was done in that area. I did have to reboot due to changes or it wouldnt work.
              9.6 final will be out next week so you wont wait for too long.
              • netsurferN
                netsurfer @spwolf
                Thank you for support. You can take it all the time; I will wait for 9.6 next week.
                Bye
