Encryption in 9.6 Beta1 is Not Working
When Encryption is selected, PA goes through the process of compressing the files but when the encryption is done, the pae file is missing. Nothing is produced.
Using shell option “Compress & Encrypt” ?
The pae file is created, but it is saved in the “Temp Location” folder (Configuration - Folders); not in the same folder as the file being compressed. -
this has been fixed in b2
The pae file is created, but it is saved in the “Temp Location” folder (Configuration - Folders); not in the same folder as the file being compressed.Yes, fixed in 9.6 Beta 2
