    Vista and power archiver
    5 Posts 4 Posters 8.8k Views
    • T Offline
      torkan
      I try power archiver 9.51 on windows vista (build 5270) and I have small problem. It crash! I think it’s the skin engine that conflic with the AERO visual system. How can I disable the skin engine WITHOUT starting power archiver.
        you can delete registry entry of PowerArchiver (or uninstall/install). Are you sure it is an skinning problem though? Did it work before you used skins?
        E 1 Reply Last reply Reply Quote 0
        • E Offline
          eduj @spwolf
          I’m new at this and I really don’t see where to post my own new questions. However, I found a download that is listed as’mIRC New releases and then the date.’ When I try to decode it, Powerarchiver says it can’t do it…and suggests I decode the last posted release. I presume there is an e-book in this release. Is there a problem with it coming from mIRC? I’m at jude50ic@charter.net TIA
          • R Offline
            rev23dev
            any word on vista support? :)
              spwolf conexware @rev23dev
              @rev23dev:
              not until they stabilize development a bit more… right now they are changing too many things in every build and our anti-piracy tools dont like it too much.
