    Convert Problem
    3 Posts 2 Posters 5.0k Views
    • J Offline
      jwebby
      When you convert a zip to gzip, PA doesn’t extract empty folders.
      I install alot of server software and some has empty folders. It’s nice to convert the zip to gzip, upload the gzip and extract on the server. This saves a lot of time & eliminates binary/ascii corruption issues.
      Maybe I’m doing something wrong or need to make a setting in PA.
      James
        problem is that our tar engine does not support empty folders right now, so they are extracted but they are not compressed to tar…
        • J Offline
          jwebby @spwolf
          Something you will be fixing in the (near) future? It would really help me out.
          Otherwise it’s a great little program.
