    Shell extension menu 'bugs'
    4 Posts 3 Posters 7.3k Views
      seth
      If the filename begins with a ‘.’ it looks like this. It might not be a bug, but it’d be nice to see something like .text.zip if there’s no text before the ‘.’ in a filename. Thanks for a great program none the less :)
      Also it’d be nice to have a right-click option to compress ISO/NRG/BIN files instead of just extract… this might in fact be a bug, or at least a possible oversight. Maybe have this option depend upon if power archiver is associated with such files or not?
        Sorry, I missed this post.
        @seth:
        Well, Windows does not allow creating a file called .xxx
        Just gives error, “there must be a filename”. Of course, you could select “Compress with options” and then give the zip another name as required.
        @seth:
        PA treats ‘iso’ files as archives, so you have to enable the shell option “Compress to… (for archives)”
          mwb1100 @TBGBe
          @TBGBe:
          The shell might not like to create files that start with a period, but other programs (including the command line or notepad) have no probelm with them.
            TBGBe @mwb1100
            @mwb1100:
            So they do. And, if you also give them an extension ‘.test.txt’ then PA also has no problem.
