    PAE problems
    6 Posts 2 Posters 7.9k Views
    • PA_FanP Offline
      PA_Fan
      Win XP Pro/SP2
      In PA 2004 I could open a Zip archive, add files to it and then encrypt the Zip to pae. If at a later date I wished to add more files to the encrypted archive, I could do so, with the “Update archive” option enabled under “Miscellaneous”. Thereafter, opening and decrytping the archive would reveal the added file(s).
      This is very useful when building up a zip gradually, encrypting all the while, and then sending finally to recipient i.e. keeps data secure all through the process.
      In PA 2006, I try to do the same thing, and my screen flashes, but the file(s) being added do not appear in the archive. Nor do I get the “update” message at all.
      I have checked and rechecked all the settings, played around with them etc but no way can I get this to work properly.
      The preferred encryption is AES 128.
      Any ideas, anyone?
        thanks - we will check it out!
        PA_FanP 1 Reply Last reply Reply Quote 0
        • PA_FanP Offline
          PA_Fan @spwolf
          I have had another look at this pae problem. It seems that if PA is not skinned with the 2006 Interface Skins, then the problem arises (i.e. this line/option is left blank).
          I have applied the Green Metal skin, and this seems to solve the problem.
          I.e.
          Create new zip archive, add files, encrypt and delete original zip. Then open pae, add a file and it works OK.
            spwolf conexware @PA_Fan
            this has been fixed in 9.51. Please check it out.
            • PA_FanP Offline
              PA_Fan @spwolf
              I have had a try or two with 9.51 and it seems OK now.
                great, closing this one…
