    Drag-N-Drop folder with relative path problem
    4 Posts 3 Posters 6.4k Views
      mwb1100
      There is a problem when trying to add a single folder to an archive (using either PA 9.26 or 9.50.26 (PA 2006 Beta 7)).
      Say that for example that I have a folder heirarchy on my disk something like:
      c:\folder1\folder2
      Each folder has files in it, and an Explorer window is open to Folder1.
      If I have “Use Normal Relative Path” unchecked, and I drag Folder2 to an archive open in PA, the archive gets the contents of Folder2. This is what I expect when the Normal Relative Path option is off.
      However, if I have the Normal Relative Option checked and I drag folder2 into the archive, the folder heirarchy that gets put into the archive starts at Folder1, not folder2 as I would expect.
      There doesn’t seem to be a way to get folder2 into the archive by drag-n-drop except by having folder1 above it.
      • K Offline
        klumy
        I can confirm this !!
        IMO this is a serious bug.
        I also reported this bug in the internal alpha bug forum some time ago
          mwb1100 @klumy
          Hey, I just downloaded PA 2006 RTM, and this problem seems to be fixed!
          I can’t believe this got fixed at such a late stage in the release cycle.
          Thanks very much!
            spwolf conexware @mwb1100
            you are welcome…
