    Powerarchiver starts faster with UPX
    4 Posts 2 Posters 8.8k Views
    • K Offline
      klumy
      Can anyone confirm this?
      If you compress the powerarc.exe with the EXE packer UPX, Powerarchiver starts much faster.
      Try it yourself
      Download
      http://upx.sourceforge.net/download/upx125w.zip
      unpack it.
      then drag your powerarc.exe from your Powerarchiver directory to the upx.exe. Make a backup of your powerarc.exe before doing this.
        ivan conexware
        Probably it stats faster (I cannot confirm this) - but there is another problem. Program compressed with UPX uses more IS-USE memory than uncompressed program.
        • K Offline
          klumy @ivan
          I can live with that, I have 512MB Ram installed. So in my case the speed improvement is more precious than the RAM loss ;)
            ivan conexware @klumy
            Sure, but we always have to think there are people still runing on Windows 9x with 16 MB of RAM in average (for those old configurations);)
