    Crash when using tray icon
    • Y
      yop
      If i extract an ISO, zip etc and minimize it to tray and leave it to finish, the tray will crash, when it’s done extracting the archive. (Without clicking on the popup that say all done)
      This also happens when compressing files and minimized to tray.
      But not when minimized to taskbar
      Using 2006b6
      WinXP SP2 Eng
      Event Type: Error
      Event Source: Application Error
      Event Category: None
      Event ID: 1000
      Date: 2005-09-26
      Time: 23:21:09
      User: N/A
      Computer: XXX
      Description:
      Faulting application powerarc.exe, version 9.5.0.25,
      faulting module kernel32.dll, version 5.1.2600.2180,
      fault address 0x0001eb33.
      For more information, see Help and Support Center at
      http://go.microsoft.com/fwlink/events.asp.
      Data:
      0000: 41 70 70 6c 69 63 61 74 Applicat
      0008: 69 6f 6e 20 46 61 69 6c ion Fail
      0010: 75 72 65 20 20 70 6f 77 ure pow
      0018: 65 72 61 72 63 2e 65 78 erarc.ex
      0020: 65 20 39 2e 35 2e 30 2e e 9.5.0.
      0028: 32 35 20 69 6e 20 6b 65 25 in ke
      0030: 72 6e 65 6c 33 32 2e 64 rnel32.d
      0038: 6c 6c 20 35 2e 31 2e 32 ll 5.1.2
      0040: 36 30 30 2e 32 31 38 30 600.2180
      0048: 20 61 74 20 6f 66 66 73 at offs
      0050: 65 74 20 30 30 30 31 65 et 0001e
      0058: 62 33 33 0d 0a b33…
      • TBGBeT
        Confirmed
        • doing ISO extraction (tray) in Beta 7 (9.50.26)
        “Exception EOSError in module POWERARC.EXE at 00010B92.
        System Error. Code: 5.
        Access is denied”
        • D
          davidsplash @TBGBe
          which operating system are u testing this on?
          • TBGBeT
            TBGBe @davidsplash
            @davidsplash:
            Both myself and yop are on Windows XP (SP2).
            Y 1 Reply Last reply Reply Quote 0
            • Y
              yop @TBGBe
              Yep still the same in b7 compress/decompress and use of tray icon will make the app crash
