Pae sfx reading fault or major fault
the program attached was downloaded several months ago and when i click on it it shows pae sfx and asks for a password it never used to have one, thats not the point the password is test found out. Well i creaded a pae sfx file with totally different files in it and used the password test for it. I tried that password on this file and it worked. However pa can not read it but it comes up with a pae sfx dialog when u click on it.
File zipped to get it on this site
attachment_t_1176_0_clonecdprofiles.zip -
I dont understand what you are saying, please david one sentence at the time.
PA does not open PAE SFX files, you have to extract them “manually”.thank you!
basically pa can not read pae sfx files
Opening PAE SFX archives within PA is not enabled.Closing thread.
