    7-zip problems AGAIN AND AGAIN AND AGAIN AND AGAIN…..
    53 Posts 9 Posters 68.6k Views
      spwolf conexware @Shivan
      all this energy wasted could have gone into more detailed bug report :-).
        Shivan @spwolf
        You’re right, spwolf!
        Sorry…
        • A Offline
          amh209 @Shivan
          Since this problem has been reported, I have been trying to reproduce it on two different machines without any success. I have been able to reproduce a crash when canceling the 7-zip file compression on large files (400MB+ with over 500+ files/folders). Hitting the cancel button has caused PA to stop responding everytime. I let PA set there for just over 20 minutes and PA never did start responding, just hung on canceling.
          But back to the original problem of missing folders, so far no luck, all the files I have created have been fine. Wish I could of been more help.
          • H Offline
            HandsomeGuy @TBGBe
            I just did a quick test right now.
            I went to the X-Setup Pro folder and selected all the files and folders and right click and selected to compress to 7z. I then did the same using WinRAR. I then compared what showed up by opening then both in WinRAR.
            Two folders were missing from the PA created 7z. These folders were Plugins and Wizards, and when I checked, these folders were both blank.
            You guys try it and let me know if you get the same thing.
            This is still a problem, as what if these blank folders are needed and PA doesn’t recreate them? Can this problem PLEASE be fixed for the next beta? I don’t want to see anything missing, no matter how insignificant PA deems it. I chose what to compress, and hence it should ALL be there.
            This is only one thing at the moment. I will try other things are I get more time.
            PS: Can I pls get a registration code for PA 2006, as I’m willing to provide my services as a beta tester for it.
            Thanks.
            ivanI TBGBeT 2 Replies Last reply Reply Quote 0
              ivan conexware @HandsomeGuy
              We fixed the problems with saving path, and now working on saving/restoring empry folders. All those things should be for BETA 4.
                TBGBe @HandsomeGuy
                @HandsomeGuy:
                The beta versions are released for public testing. You do not need a registration code to contribute to beta testing - just post here in the forums when you find problems.
                Actually, it is useful if some “beta testers” are unregistered, just to verify that there are no errors introduced which only affects them.
                PS
                :D if you really want a registration code http://www.conexware.com/order.html :D
                • H Offline
                  HandsomeGuy @TBGBe
                  Yeah, gee thanks. We can’t even get 1 code for helping testing.
                  • A Offline
                    amh209 @HandsomeGuy
                    We are all helping to make the code better. PA is a small company that is trying to provide a good rpoduct and working hard to make it affordable for home users. Along with this, they have always been very responsive with their support. I for one think that your attitude stinks and I’m tired of listening to you trash PA and complain because you can’t get something for free. If you don’t like the program, quit using it. If you want to help improve the product, offer insightful suggestions and detialed descriptions. IF you want something for free, go find an open source program. If you want to get paid, apply for a job and prove your worth.
                    Last time I will be replying to any of handsomeguys comments.
                    spwolfS H 2 Replies Last reply Reply Quote 0
                      spwolf conexware @amh209
                      easy…
                      From beta 4, empty folders are added to the 7zip archives.
                      regards,
                      • H Offline
                        HandsomeGuy @spwolf
                        easy…
                        regards,
                        Great. Thanks a lot. I can’t wait to give it a try. When will beta 4 be out? Also, what other changes does it contain?
                        • H Offline
                          HandsomeGuy @amh209
                          @amh209:
                          Relax man. I hear ur comments. I too wanna help improve PA. Ur just takin things too personal. I’ve helped test other products n got free registration codes before, so I was just seeing in PA would be the same. Just relax man.
                            TBGBe @HandsomeGuy
                            @HandsomeGuy:
                            In case you missed it - it’s out now :D
                            • H Offline
                              HandsomeGuy @TBGBe
                              Yeah, I just saw. Hope to give it a try on the weekend, time permitting. Good on ya guys.
