    P
    Will you be releasing 2024 soon?
    Standard ZIP compression using spanning ERROR!
    6965
    • xelX
      xel
      Yesterday I’ve tried to compress 6 GB data into 100 MBs split archives. The archives was named “name.z01”, and there was no main “.zip” file, just only the .z01, 02… I could not opened the archive in any case.
        did you enable “Make large zip” option before compression?
        xelX 1 Reply Last reply Reply Quote 0
        • xelX
          xel @spwolf
          Yes, of course.
            spwolf conexware @xel
            how exactly did you compress these files? Please outline it step by step so I can check it out. What version of PA are you using?
            • xelX
              xel @spwolf
              Here it is (step by step):
              PowerArchiver version: 9.25.02 (June, 2005)
              _1. I’ve selected the folder, right click on it, click on PA context menu, than selecting “Compress To ZIP + Options”.
              2. My settings:
              Compression: ZIP, Super Fast; Action: Add (and replace) files; Include system and hidden folders: yes; Save full folder info: no; Write directly into ZIP: no (not possible); Use Deflate64 compression: yes; Make larga ZIP file: yes; Encrypt archive (.PAE): no; Create solid archive: no (not possible); Profile: ZIP default; Spanning: 100MB; Spenning mode: PkZip/PA 7.0 Compatible; ZIP encryption: Disabled.
              3. When the archive is ready, no main ZIP file can be found. If I don’t use spanning, the whole archive contains CRC errors while testing._
              Thats all, I hope this helps!
                @xel:
                2. My settings:
                thanks for the info. Can you select same options in main PowerArchiver window and see if it works there? I am having trouble reproducing it and trying it out in main window might give us some important info.
                thanks a lot…
