    Upload to FTP counts -%?
    21 Posts 5 Posters 10.2k Views
    • K Offline
      KarbonKopy
      I am uploading a .7z file to my FTP and its counting completed it -%'s and not showing a progress bar. I am pretty sure its uploading the file.
      Also…when you click on cancel it seems to take it as a suggestion and you have to hit the exit button 3-4 times for the window to finally close. It does this when zipping files as well…any idea on that?
        Not sure about ftp uploading, but during Compression/Extraction “Cancel” actually means when current file operation (that’s file NOT archive) is finished.
        PA has to wait for the “library” function to return control to the GUI.
        Actually, maybe ftp is similar??
        • K Offline
          KarbonKopy
          I have attached the pic I took of it uploading to my FTP.
          As far as canceling or stopping an archive/FTP upload in progress…what is the best method? Like I said currently I hit the x button 3-4 times and it will close.
            dragon57 @TBGBe
            @TBGBe:
            I understand this is true for PA, but I wish it would cancel when you hit cancel. 7Zip, for example, cancels immediately when you tell it to, there is no waiting, no matter how large the current file happens to be.
              uploading via File> Send> FTP?
              • K Offline
                KarbonKopy
                Yeah, after I created the archive I right clicked then did PA…FTP it and then the location.
                  spwolf conexware @dragon57
                  @dragon57:
                  complaining about it is first and major step into fixing it :-)
                    spwolf conexware @KarbonKopy
                    @KarbonKopy:
                    ok, thats from shell… will take an look
                    • K Offline
                      KarbonKopy
                      Did you want me to try it from the program itself? Also…I second the suggestion that Dragon57 had…hitting cancel should probably cancel the whole thing (at least IMO). Should i start a thread in the suggestions/wishlist area?
                        @KarbonKopy:
                        yes please… and yes, you should want everything to work to your liking… then if something is not possible for whatever reason, we will say so.
                        but do not be restricted by what we say :-)
                        • K Offline
                          KarbonKopy
                          Odd spwolf….I tried another file and its at 100% uploaded (done same way) but there is no way its done…its a 6 GB file (other was 2gb) both were done in the same way. I just tried to upload them by opening PA and it stays at 0 bytes and wont even attempt to upload. Hmmm.
                            ok, we will try from our end…
                            • K Offline
                              KarbonKopy
                              OK I closed PA and reopened…and inside PA I did another upload (same file and it is now uploading…but has the same issue (% doesn’t change on this one). Must be a % based issue…hope I was of help!
                                very helpful!
                                  Socrates Banned @spwolf
                                  I have been watching this thread. I have tried it several times, and the progress bars and the %s are working just fine.
                                  I have tried it within PA and using the shell. Works fine either place.
                                  Odd
                                    i suspect it has something to do with files over 2 GB / 4GB and since this entirely new component in 2011, it makes sense.
                                      Does make sense.
                                      But I am giving it a test right now. If my results are different, I will let you know. But FTPing a file in excess of 2 gig will definitely take some time.
                                        Socrates Banned @Socrates
                                        I did not wait for it to finish.
                                        For what it is worth, I got a slightly different result.
                                        My progress started at above 250% – and it was counting down (252, 251, 250 . . .)
                                          that was file over 2 GB?
                                            yes . . . about 2.6
