    A ASkripts
    Wishlist
    W Werve
    Wishlist
    2 Votes
    Z ZebraPower
    Wishlist
    PA_FanP PA_Fan
    Wishlist
    C charlesbotz
    Wishlist
    paq9a support
    R richwood
    Wishlist
    Wishlist
    Wishlist
    BigMikeB BigMike
    Wishlist
    OneDrive for Business support
    Z ZebraPower
    Wishlist
    BigMikeB BigMike
    Wishlist
    2 Votes
    A a.borque
    Wishlist
    BigMikeB BigMike
    Wishlist
    F falco99
    Wishlist
    D DaTreeDude
    Wishlist
    2 2Flo
    Wishlist
    Wishlist
    Folder navigation
    drteethD drteeth
    Wishlist
    Quake 1/2 .PAK file support
    AluminumHasteA AluminumHaste
    Wishlist
    Find file in archive.
    Wishlist
    Patchbeam Link via System Tray
    9 Posts 6 Posters 6.7k Views
    • RJWaringR Offline
      RJWaring
      Hi Guys,
      It would be great if you could add a simple “Update Now” link via PA Starter in the system tray.
      This as simple as a request it is would be welcomed so users do not have to open the application to go through the update process.
      • LuxorL Offline
        Luxor Alpha Testers
        Are you reading my mind Sir Richard? :eek:
        That is the very thought I had just been thinking before I arrived here today.
        So a big +1 from me.
        Shouldn’t be to hard to do should it? ;)
        Windows 10 Home 64-bit
          gonna log that one in the wishlist, we’ll see how doable it is
          thanks, danke, gracias, hvala, aloha, powerarchiver.
          • LuxorL Offline
            Luxor Alpha Testers @Mili
            @Mili:
            We have faith in your abilities Mili :D
            • moles42M Offline
              moles42 Alpha Testers
              sounds handy if you’re a PA Starter user…unfortunately I’m not…:)
              Windows 10 Pro x64
              Intel Core i5 3470 @ 3.20GHz
              8.00GB Dual-Channel DDR3
              • RJWaringR Offline
                RJWaring @moles42
                @moles42:
                You should! its the future! :D
                  isnt the easiest to use silent update and you dont even notice it until you close PA? :-)
                  that way it is both automatic and you get it next time you use PA.
                  • guidoG Offline
                    guido
                    Just check Paint.net. That’s the best way I guess
                    Windows 11 Pro ENU x64
                    Intel Core I7
                    32 GB RAM
                    • RJWaringR Offline
                      RJWaring @spwolf
                      less excuses, more action ;) Customers rule in favour you know what that means.
                      Just set a link to run a script that opens PA and then the PatchBeam Command.
                      Im sure a man with you abilities can throw something togeather quicker than a brit drinks a cup of Tea!
