    Wishlist
    Wishlist
    Optimize Office Documents (Does not work on multiple)
    Wishlist
      Mameluke
      HI there
      Title says it all.
      Select several Docx documents and then rght click them. All compression options show up on the context menu but not the optimize office document one.
      It works only on one file at a time.
      PA version 11.62.04
      Vista 64 bit
      4 Gig Ram
      Mame
      • moles42M
        moles42 Alpha Testers
        confirmed in windows 7 ultimate x64
        Windows 10 Pro x64
        Intel Core i5 3470 @ 3.20GHz
        8.00GB Dual-Channel DDR3
          you can select only single file currently… moving it to wishlist… thanks!
            Mameluke @spwolf
            Would really be helpful especially when having to optimize many (more than 50-60) :D
            Mame
