Lzma2
 Any planning to use lzma2 in future?
 http://dl.7-zip.org/lzma2_466a.7z
 as soon as it is released in some form of usable state (that will be compatible with future versions)…
 as soon as it is released in some form of usable state (that will be compatible with future versions)… good news
 PowerArchiver 2010 11.63.13.
 Changes:
 7zip engine updated and added support for extracting LZMA2 archives.What about support to use LZMA2 with packing? Optimized compr.?
 for packing sure in pa 2011, not sure yet about optimized
