    Wishlist
    Wishlist
    Better compression methods for files
    Wishlist
    • D
      davidsplash
      better compression methods for use on file types. this is possible i would like pa to beable to compress say a jepg differently to a txt file and still zip up the files into the same zip file.
      So you can take advantage of better compression rates for different files.
        how can it be the same zip file if it is compressed differently? :-)
        • D
          davidsplash @spwolf
          I was using zip as an example it can be 7zip for instance , but the files within that archive are compressed to a format that best compresses them using the archive as a container for the files.
            our 7z is already doing this… did you see post about optimized compression? It is exactly what this is.
            • D
              davidsplash @spwolf
              yes but i need this option on a different archives
