In Windows 11 a new explorer context menu is introduced.
The “old” context menu may still be accessed through an additional mouse click, to reach the PowerArchiver context menu functions, but this isn’t comfortable at all.Could you add PowerArchiver items to the first level (and ideally disable the Windows native ZIP entry)
I’d like to propose an improvement for password protected archives.
Actual behavior is:
If I open an archive, which is password protected and make a typo in the password dialog, I’ll get the message, that the password was wrong and I end up with an empty window. I need to reopen the archive to be able to enter the password again.Improved behavior:
Tell me, that the password was wrong and give me the chance to enter the correct password to decrypt the archive. -
I know I have been asking for this feature some time ago, but as nothing has changed let me ask again:
The ZIPX-format offers an algorithm, that compresses JPEG-files by about 20-30%. Please add compression (packing) support for this in ZIPX-archives to Powerarchiver. Extraction of JPEGs packed into ZIPX by this algorithm is already supported by Powerarchiver for a long time, so it should not be difficult? Or is it a licensing problem?
Thanks! -
So XPI files (Firefox addons) for example are ZIP files. PowerArchiver opens them without any problems, but if I try to add file by drag & drop, PowerArchiver won’t auto select “ZIP”, but use the last selected archive format, while PowerArchiver already knows, that I’m trying to add files to a ZIP. -
I love this, only there is one problem. The UAC elevation feature does not extend to Mount Image option in the add-on software PA provided. It is most annoying whenever I am on highest UAC settings and I mount an ISO, every time I open and create a virtual drive UAC appears. I also do not want to completely disable UAC.
Is adding UAC elevation for mount image feature possible?
Hi.
I noticed that when I want to run the Virtual Drive for the first time inside the PowerArchiver Burner it prompts to download it form the internet.
I was wondering, would it be OK to include this utility straight into the offline installer to be able to set it up locally?
Thank you!
Libreoffice/Openoffice ODF documents are all, as far as I am aware, just renamed .zip files. (.odt, .ott, .ods, .ots, .odp, .otp, .odb, .odf etc.) -
Reason I ask is that I was looking for a certain file I knew existed in an archive, but I had to unzip it then use another tool to find the file. It would have saved that extra step if that function existed in PA itself. -
Hi.
Is there a way to enable the user to encrypt the files inside a ZIPX archive that has already been created?
This could save time for large archives that the user may need to encrypt at a later stage or that he/she has forgotten to enable encryption before creating the archive,
Thank you!
Hi.
I would like to see a new feature implemented: a ‘Fast Extract’ Mode.
Currently PowerArchiver extracts files to a temporary directory and then moves them to the target directory chosen by the user. At least via drag and drop.
This can be both time consuming and needs free space on the system drive for large files.
Is there a way to directly extract files to the target directory with PowerArchiver?
And if not, can a feature like this be considered for future updates?Thanks very much!
Hello.
I believe it would be useful to implement Serpent-256 encryption for PAE/PAE2 formats, even though PowerArchiver offers strong encryption ciphers already.
(deleted part advertising other software - admin)
Do you think this will be a useful addition?
Thank you for the consideration!
I think it would be a great option to make the portable version of PowerArchiver compatible with PortableApps (i.e. adding the necessary files and folders to integrate it smoothly into their structure).
I own various other commercial programmes which -when installed in portable mode- offer to make the becessary changes without needing an extra installer or the official PortableApps repos.
Thanks for opinions or perhaps even a realization of this.
A.Borque -
Presently, PowerArchiver 2019 (any build) cannot rename PBS filenames by single clicking on such entry or right-click menu has no “Rename” feature!
Hmm, even pressing F2 on selected entry does nothing :(
Virtual Drive enhancements/improvements
Would like to suggest following improvements on Power Archiver’s Virtual Drive handlings.
1. In PA-configuration, pls allow users to ‘set’ a fixed driveletter for their Virtual Drive, e.g. ‘Z’, or so.
Some users, like me, may be using external drives.
On top, I myself, am using a program called Bestcrypt, that creates password protected containers and which can be handled like any other drive, but require their own driveletters.Once you open a Virtual Drive and thén switch on an external drive, or open a Bestcrypt-container (Jetico.com) the driveletters tend to get mixed up.
One shd go into Diskmgt to reset everything and assign the driveletters the way there were and shd be.
With ‘Z’ as a fixed Virtual Drive this will hardly be the case.
-Or, alternatively prompt users to tell PA what driveletter once they mount an .iso2. Add unmount to the context menu: users to click on the Virtual Drive - RMB - unmount.
No need to launch PA, go into the burner menu and go thru the few steps to unmount a drive.
Am not sure whether this requires a great deal of programming though. Actually the RMB click wud call the same procedure as right now, only, without showing windows and asking to click on ‘next’/‘next’/‘close’…
Vote to have the UNMOUNT voice in the context menu…tonight I spent half an hour to understand why I could not unmount a volume created by PA…before coming to the forum.
It’s just crazy to have to launch PA again to unmount virtual drives!!
makes sense…
Check in 11.03 via web update - you will be able to skip few steps by launching unmount tool from PA Starter (you will still have to select what to unmount for now)… so it should save some time. Keep in mind that until PAVD.EXE is updated (monday), unmount will not go directly to unmount but to PAVD main screen.
It is still not as useful as right click> Unmount> D:, but it will definetly help. We dont have time for anything else in minor releases, expect more improvements in PA 2010 :-).
sorry for my late reply. as it is now, is already a big step ahead, thank you :)
