    A ASkripts
    Wishlist
    W Werve
    Wishlist
    2 Votes
    Z ZebraPower
    Wishlist
    PA_FanP PA_Fan
    Wishlist
    C charlesbotz
    Wishlist
    paq9a support
    R richwood
    Wishlist
    Wishlist
    Wishlist
    BigMikeB BigMike
    Wishlist
    OneDrive for Business support
    Z ZebraPower
    Wishlist
    BigMikeB BigMike
    Wishlist
    2 Votes
    A a.borque
    Wishlist
    BigMikeB BigMike
    Wishlist
    F falco99
    Wishlist
    D DaTreeDude
    Wishlist
    2 2Flo
    Wishlist
    Wishlist
    Folder navigation
    drteethD drteeth
    Wishlist
    Quake 1/2 .PAK file support
    AluminumHasteA AluminumHaste
    Wishlist
    Find file in archive.
    Wishlist
    32bit Shell Extensions for Vista 64bit Needed
    15 Posts 3 Posters 21.1k Views
    • C Offline
      crunch
      Creating wishlist topic per spwolf’s request.
      Reference: http://www.powerarchiver.com/forums/showthread.php?p=13921#post13921
      • C Offline
        crunch
        It’s been almost a week, could I get a confirmation / eta for this please.
        Thanks.
          we never comment on wishes, until it is time to implement them or they were implemented…
          future major release.
          • C Offline
            crunch @spwolf
            Please advise whether this will be fixed in PA 2009. Thank you.
              spwolf conexware @crunch
              @crunch:
              we will implement the feature eventually, but i can not promise you when… and i could not find any threads on tc website on how to do it from original article, that might speed things up.
                both threads you specify on original post, dont have any info except that it doesnt work…
                I certainly could not find info on how to make it work or how other programs made it work? I might be blind and it is late here too…
                  mwb1100 @spwolf
                  I don’t run a 64-bit OS, so I’m not really sure if this will work, but if you can install both 32-bit and 64-bit PA side-by-side on the machine you should get both 32 and 64-bit shell extensions.
                  I do know this worked for an acquaintance that wanted 32 and 64-bit extensions for 7Zip.
                  • C Offline
                    crunch @mwb1100
                    http://www.mythicsoft.com/kb/KnowledgebaseArticle10020.aspx
                    I would try option 2, however the path should be dynamic and not hard-coded (needs to point to actual install path).
                      @crunch:
                      it really has nothing to do with what we need to do :-).
                      Is there an app that does it from install? So we can see how they are doing it.
                      But if I am thinking right, we would have to install two distinctivly different shell extensions which I am not sure that will work properly right now - in fact, i am sure it wont.
                      I will put it on the wishlist for 11.5…
                      • C Offline
                        crunch @spwolf
                        Men, I’m seeing some truly fantastic features being implemented in PA 2009. And it kills me because these features are right up my alley and I’d be able to offer some really good feedback & suggestions, as I have in the past. But without 32-bit extensions working for 64-bit Vista the program is dead in the water for me. This situation is making me quite blue…
                          @crunch:
                          it is not simple - it will take a lot of our time, since way we access shell extensions right now would have to be changed due to 2 extensions installed at the same time…. so thats why no way we could have done it for 11.00…
                          • C Offline
                            crunch @spwolf
                            Okay…
                            • C Offline
                              crunch @crunch
                              Is there any way the method for choosing which extension is installed/used can be user-configurable? At the moment I believe the installer is making a default decision based upon which version of OS is detected (since there aren’t separate downloads for 32-bit / 64-bit).
                              This would at least offer a choice for people that need PA to work with 32-bit apps running on 64-bit Windows and wouldn’t require changing the system for accessing shell extensions to allow 2 concurrent shell extensions, one for each architecture…
                              Another idea is splitting up the versions, one for 32-bit and one for 64-bit. True, having one installer for both versions is cooler…but this isn’t working 100% yet. If there were separate installers it might be possible to install them to separate directories and ‘hack’ compatibility for both architectures temporarily, no?
                              It doesn’t have to be pretty for now - we understand it will take fundamental changes for it to be done the right way - but please at least offer a temporary workaround. This is a blocking situation (there, I didn’t call it a bug ;)).
                                mwb1100 @crunch
                                @crunch:
                                I’m finding that I need this support too (running 64-bit XP Pro and wanting to use a 3rd party filemanager that’s 32-bit only).
                                I’m near certain that if you made a 32-bit-only installer available that I could get this to work well enough by having 32 and 64 bit PAs installed side-by-side. This workaround works for other shell extenders (TortoiseSVN for example).
                                  Its party time :D
