    Filename problem "3 0 0 .part001"
    22 Posts 6 Posters 17.3k Views
    • guidoG Offline
      guido
      I don’t know if this is a double post. But I couldn’t find the old one.
      Pa cannot extract a filename with he following name:
      3 0 0 .part001
      You get a permission error.
      Windows 11 Pro ENU x64
      Intel Core I7
      32 GB RAM
      • guidoG Offline
        guido
        not fixed in .15
        Intel Core I7
        32 GB RAM
          p.s. thanks for all the updates
          • guidoG Offline
            guido @spwolf
            1408_2007 .part001.rar
            • spanned rar
            • 94 files, 50 mb each
            Gives the same error message
            Intel Core I7
            32 GB RAM
              ivan conexware
              You will get this error with every archive that has space before dot and extensions. You cannot create a directory with space on the end. The same error gives any other archive utility.
              • guidoG Offline
                guido
                I could extract it fine with WnRR.
                Intel Core I7
                32 GB RAM
                • L Offline
                  lagmer @guido
                  i have asimilar problem.
                  i cant extract splitt rar archives like
                  archive.rar
                  archive.001
                  archive.002
                  archive.003
                  archive.004
                  archive.005
                  archive.006
                  and so on and so on.
                  also my right click menu doesnt show ANY powerarchiver options. so this program is useless for me.
                  • guidoG Offline
                    guido
                    @lagmer
                    The right click on the rar file should work.
                    Intel Core I7
                    32 GB RAM
                    • L Offline
                      lagmer @guido
                      No, there isnt anything related to powerarchiver in right click.
                      Thats the problem… everything works fine with winrar. But i have paid for powerarchiver beacuse i like it better.
                      Without right drag click this program i useless for me.
                        You mean you dont get right click menus at all?
                        I think first thing to check is to go Options and click on set default. That should reset it.
                        thanks.
                        • guidoG Offline
                          guido
                          not fixed
                          Intel Core I7
                          32 GB RAM
                          • A Offline
                            amh209
                            Does that mean there is an alpha release out there?
                              spwolf conexware @amh209
                              @amh209:
                              apperantly, guido thinks there are 16 of them!
                                • guidoG Offline
                                  guido
                                  Not fixed in b1
                                  Intel Core I7
                                  32 GB RAM
                                    • guidoG Offline
                                      guido
                                      Also not fixed in b3
                                      Intel Core I7
                                      32 GB RAM
                                      • guidoG Offline
                                        guido
                                        Not fixed in .65
                                        Intel Core I7
                                        32 GB RAM
                                        • B Offline
                                          Botta @ivan
                                          @ivan:
                                          To resolve this problem, when you create a folder from the name and this has a space in the end, WinRAR automatically replaces the space at the end with a “_”
                                            Please try with final pre-release version:
                                            http://www.powerarchiver.com/test/release10/powarc1100rc5.exe
                                            And let us know if this has been improved right away.
