    Wishlist
    Wishlist
    Sound notification for events option
    Wishlist
    • C
      crunch
      I wondered if it might be possible to add an [toggle enable/disable] option to play the system exclamation (‘Windows XP Exclamation.wav’ in Sound applet) when done extracting an archive if the PA window doesn’t have focus? WinRAR does this and I find it useful to alert me that the archive has finished extracting. I think it also does it when it finishes creating an archive, that would be useful as well.
      • B
        By-Tor
        I support this wish as well. I actually had been thinking about that the other day.
