    Wishlist
    Wishlist
    Z
    Wishlist
    PA_FanP
    Wishlist
    Wishlist
    paq9a support
    R
    Wishlist
    Wishlist
    Wishlist
    BigMikeB
    Wishlist
    OneDrive for Business support
    Z
    Wishlist
    BigMikeB
    Wishlist
    Wishlist
    BigMikeB
    Wishlist
    F
    Wishlist
    Wishlist
    Wishlist
    Wishlist
    Folder navigation
    drteethD
    Wishlist
    Quake 1/2 .PAK file support
    AluminumHasteA
    Wishlist
    Find file in archive.
    Wishlist
    7zip need better ratio in PA
    10 Posts 3 Posters 12.2k Views
    • ? This user is from outside of this forum
      Guest
      I tried with many options in 7-Zip to improve my compression ratio and I think that it will be good if PA Developers add this options to PA.
      And noone archiver test crush new PA compression ratio in any tests.
      I think that this formula should be use in Ultra mode
      or You need add this formula in Extreme Mode ;]
      And this formula for Parameters bring the best compression ratioand about increase PA ratio about 1-4%, and for me is big diffrence
      [b]x=9 s=on f=on hc=on hcf=on mt=on a=1 mf=bt4 fb=273 mc=1000000000 lc=0 lp=0 pb=0[/b]
      and some explanation:
      x=9
      (level of compression)
      options: x=[0 | 1 | 5 | 7 | 9] ,
      higher number=better ratio
      s=on
      (solid mode)
      options: s=[off | on]
      on gives better ratio
      f=on
      (filters for executable files: dll, exe, ocx, sfx, sys)
      options: f=[off | on]
      hc=on
      (archive header compressing)
      options: hc=[off | on]
      hcf=on
      (full archive header compressing)
      options: hcf=[off | on]
      mt=on
      (multithread mode)
      options: mt=[off | on | {N}]
      on gives faster processing time
      **a=1
      **(compressing mode)
      options: a=[0|1]
      mf=bt4
      (Match Finder for LZMA)
      options: mf={MF_ID}
      bt2 = d9.5 + 4 MB = Binary Tree with 2 bytes hashing.
      bt3 = d
      11.5 + 4 MB = Binary Tree with 3 bytes hashing.
      bt4 = d11.5 + 4 MB = Binary Tree with 4 bytes hashing.
      hc4 = d
      7.5 + 4 MB = Hash Chain with 4 bytes hashing.
      the bt=4 provide the better compression ratio
      fb=273
      (fast bytes for LZMA)
      options: fb={N} where N=<5,273>
      mc=1000000000
      (cycles (passes) for match finder)
      options: mc={N} where N=<0,1000000000>
      lc=0
      (literal context bits (high bits of previous literal))
      options: lc={N} where N=<0,8>**
      lower number**=better ratio
      lp=0**
      (literal pos bits (low bits of current position for literals))
      options: lp={N} where N=<0,4>
      lower number=better ratio
      pb=0
      (pos bits (low bits of current position))
      options: pb={N} where N=<0,4>
        Guest
        noone intrested add Extreme mode to 7zip compression to improve ratio :(
        • RJWaringR Offline
          RJWaring @Guest
          I must admit I use 7zip for 90% of all my compression at work due to using Spreadsheets, Databases and word documents.
          If there is an improvement to the compression ratio then its worth looking into.
          However, it’s down to the PA Crew and the time it would take to develop and maintain for on going versions of 7Zip and PA.
            More important - what is speed difference? 50% slower? :-)
            ? 1 Reply Last reply Reply Quote 0
              Guest @spwolf
              Nope :p, but too my surprise it was faster than normal settings in 7-Zip
              And some test on about 350 files (doc, wav, mpeg etc.) in 1 folder:
              uncompressed folder
              335 MB (352.235.162 bytes)
              compressed in PA2007b9 (soild, Ultra mode)
              224 MB (235.877.605 bytes)
              10min 58 sek :D PA OWNS!!! :cool:
              compressed in 7-Zip 4.44beta (soild, Ultra mode, Dictionary 48MB and other settings on default)
              224 MB (235.136.186 bytes)
              14min 35sek
              compressed in 7-Zip 4.44beta (soild, Ultra mode, Dictionary 48MB and parameters like x=9 s=on f=on hc=on hcf=on mt=on a=1 mf=bt4 fb=273 mc=1000000000 lc=0 lp=0 pb=0
              202 MB (211.952.354 bytes)
              14min 17sek
              this test was performed on PIII 900Mhz, 768MB RAM
              and I think that settings for 7zip in PA2007 + Yours super mega tweaks improve compression speed = Super PA 2007 with the best compression ratio on the world :p
              You may test normal PA2007 settings (Ultra, Solild) and my setting on PA2007
              and You see what settings are better, because I dont have access to developer console :p
              and I dont know what settings are better, because this test was performed only in 7-Zip
                Here is the problem - if we use same settings as 7zip, speed will be the same :-).
                So it is better to have 2% worse compression and get a lot faster speed….
                ? D 2 Replies Last reply Reply Quote 0
                  Guest @spwolf
                  Yep, I agree with You :p
                  But I was thinking that, PA use only modified code with some compilation improvement for todays procesors ;)
                  Well, this topic should be closed now :cool:
                    deity @spwolf
                    Hmm…packing
                    Vista x64(Atlon 64 3500+), PA 2007 beta, 7 zip 4.45 beta x64
                    PA- 1m24s
                    7z 4.45- 1m08s
                      there are several things that might go there - like did you try compress each several times? For instance if you try 7z later, it will be faster since Windows cached the file already.
                      In our tests, it is 10% faster, and gets 1% less compression, with files that can be compressed (unlike driver installation you tried)… Testing can also vary based on type of file you are testing as well…
                        deity
                        In my tests in same cases(dif. files and queue) PA did best compression, but ALWAYS bad time…
                        I think it may be only for Vista x64… 7 zip - 64bit!!! and PA only 32 bit…
