    Wishlist
    Wishlist
    Power Archiver Registration Codes
    Wishlist
    • B
      brj_maverick
      Hi
      We are currently utilising a custimised ADM file with Group Policies to push our registration info to clients. With Power Archiver 2007 using the same keys but different code it becomes impossible to run it as the GPO replaces the keys. This will also become an issue during rollout.
      Is there any way Power Achiver could be set to use a new Reg Num key for 2007 instead of the same reg num key for each version?
        contact support via above link please…
