I prefer to use light themes, and when, for example, I have set up my main archive screen to be Classic Toolbar with Blizzard Blue, files in the archive are highlighted (no checkboxes, full row select) with white text on grey background. They are easy to see .
However, in the Add screens, the files and folders are black type upon a pale blue background, which is not so readily visible, especially when highlighting separate files in lists with Ctrl/Click for addition. It would be ideal if the backgrounds to files in these screens could be set to mimic the highlighting of those in the main archive window.
I have tried experimenting with different themes and settings for skins, toolbars and so forth, but, unless I’ve missed something, none seem to give me the effect I want.
Re: Windows 11 Context menu support
It would really make me happy if you put .BH in the Windows 11 context menu. I know it’s in the “More Options” section, but this would make it more convenient. Don’t know why the option to add it to the menu isn’t there in the first place. P-L-E-A-S-E ??? :) Thanks You!
In Windows 11 a new explorer context menu is introduced.
The “old” context menu may still be accessed through an additional mouse click, to reach the PowerArchiver context menu functions, but this isn’t comfortable at all.
Could you add PowerArchiver items to the first level (and ideally disable the Windows native ZIP entry)
I’d like to propose an improvement for password protected archives.
Actual behavior is:
If I open an archive, which is password protected and make a typo in the password dialog, I’ll get the message, that the password was wrong and I end up with an empty window. I need to reopen the archive to be able to enter the password again.
Improved behavior:
Tell me, that the password was wrong and give me the chance to enter the correct password to decrypt the archive.
I know I have been asking for this feature some time ago, but as nothing has changed let me ask again:
The ZIPX-format offers an algorithm, that compresses JPEG-files by about 20-30%. Please add compression (packing) support for this in ZIPX-archives to Powerarchiver. Extraction of JPEGs packed into ZIPX by this algorithm is already supported by Powerarchiver for a long time, so it should not be difficult? Or is it a licensing problem?
So XPI files (Firefox addons) for example are ZIP files. PowerArchiver opens them without any problems, but if I try to add file by drag & drop, PowerArchiver won’t auto select “ZIP”, but use the last selected archive format, while PowerArchiver already knows, that I’m trying to add files to a ZIP.
I love this, only there is one problem. The UAC elevation feature does not extend to Mount Image option in the add-on software PA provided. It is most annoying whenever I am on highest UAC settings and I mount an ISO, every time I open and create a virtual drive UAC appears. I also do not want to completely disable UAC.
Is adding UAC elevation for mount image feature possible?
Libreoffice/Openoffice ODF documents are all, as far as I am aware, just renamed .zip files. (.odt, .ott, .ods, .ots, .odp, .otp, .odb, .odf etc.)
Reason I ask is that I was looking for a certain file I knew existed in an archive, but I had to unzip it then use another tool to find the file. It would have saved that extra step if that function existed in PA itself.
How about a system tray icon?
It’d be nice to add a system tray icon for PA, as I prefer to access a lot of my commonly used programs from there.
Also, how about a button while it is compressing to let it run in the background. I compress a lot of very large directories, and would like the option to grab back some of my processing power for my main work apps.
It has this. Press Tray on the compress window.
It will use less process power when in tray
Guido
Okay cool. However, I was referring to a more permanent icon that is always resident in the tray, offering access to a custimzable menu of stuff, such as items from the tools menu. Just an idea.
