    A ASkripts
    Wishlist
    W Werve
    Wishlist
    2 Votes
    Z ZebraPower
    Wishlist
    PA_FanP PA_Fan
    Wishlist
    C charlesbotz
    Wishlist
    paq9a support
    R richwood
    Wishlist
    Wishlist
    Wishlist
    BigMikeB BigMike
    Wishlist
    OneDrive for Business support
    Z ZebraPower
    Wishlist
    BigMikeB BigMike
    Wishlist
    2 Votes
    A a.borque
    Wishlist
    BigMikeB BigMike
    Wishlist
    F falco99
    Wishlist
    D DaTreeDude
    Wishlist
    2 2Flo
    Wishlist
    Wishlist
    Folder navigation
    drteethD drteeth
    Wishlist
    Quake 1/2 .PAK file support
    AluminumHasteA AluminumHaste
    Wishlist
    Find file in archive.
    Wishlist
    Comment Window Pane: Remember Size?
    4 Posts 2 Posters 6.4k Views
    • MarcFouM Offline
      MarcFou
      The comment window pane does not currently retain its size.
      Reproduce:
      1. Open an archive with a comment
      2. Resize the comment window pane
      3. Exit PA and reopen the archive
      4. Comment window pane is restored to default size
      *If you dont have comments ‘on’ then you can click the comment balloon in the lower right corner, and in the comment dialog check mark “Show comments”. Then you can use instructions above to reproduce.
        moved to the wishlist… thanks
        MarcFouM 1 Reply Last reply Reply Quote 0
        • MarcFouM Offline
          MarcFou @spwolf
          I was actually debating if this qualified as a request or…? But as a wish, it seems like it may be a simple one :D
            spwolf conexware @MarcFou
            few other windows left to implement resizing for as well as saving the size of the window…
