Navigation
    • Windows Store Delivery (and ideally updates)
      T
      Wishlist
    • What features do you want in new format?
      spwolf
      Wishlist
    • Support for Zstandard .zst/.zstd archives
      Z
      Wishlist
    • Windows 11 Context menu support
      BigMike
      In Windows 11 a new explorer context menu is introduced.
      The “old” context menu may still be accessed through an additional mouse click, to reach the PowerArchiver context menu functions, but this isn’t comfortable at all.
      Could you add PowerArchiver items to the first level (and ideally disable the Windows native ZIP entry)
      Wishlist
    • OneDrive for Business support
      Z
      Wishlist
    • Better handling for protected archives
      BigMike
      I’d like to propose an improvement for password protected archives.
      Actual behavior is:
      If I open an archive, which is password protected and make a typo in the password dialog, I’ll get the message, that the password was wrong and I end up with an empty window. I need to reopen the archive to be able to enter the password again.
      Improved behavior:
      Tell me, that the password was wrong and give me the chance to enter the correct password to decrypt the archive.
      Wishlist
    • ZIPX: Add support for packing JPEG with specialized algorithm
      I know I have been asking for this feature some time ago, but as nothing has changed let me ask again:
      The ZIPX-format offers an algorithm, that compresses JPEG-files by about 20-30%. Please add compression (packing) support for this in ZIPX-archives to Powerarchiver. Extraction of JPEGs packed into ZIPX by this algorithm is already supported by Powerarchiver for a long time, so it should not be difficult? Or is it a licensing problem?
      Wishlist
    • Better archive type handling with drag & drop
      BigMike
      So XPI files (Firefox addons) for example are ZIP files. PowerArchiver opens them without any problems, but if I try to add file by drag & drop, PowerArchiver won’t auto select “ZIP”, but use the last selected archive format, while PowerArchiver already knows, that I’m trying to add files to a ZIP.
      Wishlist
    • Elevation of UAC in Mounting Images
      F
      I love this, only there is one problem. The UAC elevation feature does not extend to Mount Image option in the add-on software PA provided. It is most annoying whenever I am on highest UAC settings and I mount an ISO, every time I open and create a virtual drive UAC appears. I also do not want to completely disable UAC.
      Is adding UAC elevation for mount image feature possible?
      Wishlist
    • Bulkzip Nanozip (.nz) file format
      Wishlist
    • Include Virtual Drive as standalone in the installer
      Hi.
      I noticed that when I want to run the Virtual Drive for the first time inside the PowerArchiver Burner it prompts to download it form the internet.
      I was wondering, would it be OK to include this utility straight into the offline installer to be able to set it up locally?
      Thank you!
      Wishlist
    • Suggestion to improve .pa format
      Brian Gregory
      Libreoffice/Openoffice ODF documents are all, as far as I am aware, just renamed .zip files. (.odt, .ott, .ods, .ots, .odp, .otp, .odb, .odf etc.)
      Wishlist
    • Folder navigation
      drteeth
      I would like to make a further plea for my mouse’s backwards and forwards keys to work when navigating to and from files, just like they do in explorer. IIRC, I was told that this functionality would be added to v2019.
      Mni tnx.
      Wishlist
    • Quake 1/2 .PAK file support
      AluminumHaste
      I use PA for everything, if I can.
      Would be really nice to maybe get built in support for Quake 1/2 .pak files.
      More info on the format, seems simpler than I thought: https://quakewiki.org/wiki/.pak
      Wishlist
    • Find file in archive.
      Luxor
      Reason I ask is that I was looking for a certain file I knew existed in an archive, but I had to unzip it then use another tool to find the file. It would have saved that extra step if that function existed in PA itself.
      Wishlist
    • Encrypt files inside archive that has already been created [.zipx]
      Hi.
      Is there a way to enable the user to encrypt the files inside a ZIPX archive that has already been created?
      This could save time for large archives that the user may need to encrypt at a later stage or that he/she has forgotten to enable encryption before creating the archive,
      Thank you!
      Wishlist
    • Fast Extract large files directly to target directory
      Hi.
      I would like to see a new feature implemented: a ‘Fast Extract’ Mode.
      Currently PowerArchiver extracts files to a temporary directory and then moves them to the target directory chosen by the user. At least via drag and drop.
      This can be both time consuming and needs free space on the system drive for large files.
      Is there a way to directly extract files to the target directory with PowerArchiver?
      And if not, can a feature like this be considered for future updates?
      Thanks very much!
      Wishlist
    • Serpent-256 Encryption for PAE/PAE2
      Hello.
      I believe it would be useful to implement Serpent-256 encryption for PAE/PAE2 formats, even though PowerArchiver offers strong encryption ciphers already.
      (deleted part advertising other software - admin)
      Do you think this will be a useful addition?
      Thank you for the consideration!
      Wishlist
    • Make portable version compatible with PortableApps
      I think it would be a great option to make the portable version of PowerArchiver compatible with PortableApps (i.e. adding the necessary files and folders to integrate it smoothly into their structure).
      I own various other commercial programmes which -when installed in portable mode- offer to make the becessary changes without needing an extra installer or the official PortableApps repos.
      Thanks for opinions or perhaps even a realization of this.
      A.Borque
      Wishlist
    • PBS Filenames
      Presently, PowerArchiver 2019 (any build) cannot rename PBS filenames by single clicking on such entry or right-click menu has no “Rename” feature!
      Hmm, even pressing F2 on selected entry does nothing :(
      Wishlist
    Speed improvement compressing/extracting
    Wishlist
    • guido
      guido last edited by
      I wish for speed improvent for compressing/extracting in al formats.
      But I use Rar and 7z the most :D
      I must add to that, that the speed is the most named thing for people to go back to WnRr.
      Guido
      Windows 11 Pro ENU x64
      Intel Core I7
      32 GB RAM
      • spwolf
        speed is related with compression. It most cases we tested, Maximum (not ultra) compression is better in 7zip than best possible in WR.
        7zip compression speed has improved a lot in last few months, huge improvements really I doubt it can be improved much more.
        • guido
          Fixed in b2
          Intel Core I7
          32 GB RAM
          • B
            bulat last edited by
            what compression mode you use (fast/bormal/max/ultra) ? optimized, probably?
