Navigation
    • Include Virtual Drive as standalone in the installer
      Hi.
      I noticed that when I want to run the Virtual Drive for the first time inside the PowerArchiver Burner it prompts to download it form the internet.
      I was wondering, would it be OK to include this utility straight into the offline installer to be able to set it up locally?
      Thank you!
      Wishlist
    • Suggestion to improve .pa format
      Brian Gregory
      Libreoffice/Openoffice ODF documents are all, as far as I am aware, just renamed .zip files. (.odt, .ott, .ods, .ots, .odp, .otp, .odb, .odf etc.)
      Wishlist
    • Folder navigation
      drteeth
      I would like to make a further plea for my mouse’s backwards and forwards keys to work when navigating to and from files, just like they do in explorer. IIRC, I was told that this functionality would be added to v2019.
      Mni tnx.
      Wishlist
    • Quake 1/2 .PAK file support
      AluminumHaste
      I use PA for everything, if I can.
      Would be really nice to maybe get built in support for Quake 1/2 .pak files.
      More info on the format, seems simpler than I thought: https://quakewiki.org/wiki/.pak
      Wishlist
    • Better archive type handling with drag & drop
      BigMike
      So XPI files (Firefox addons) for example are ZIP files. PowerArchiver opens them without any problems, but if I try to add file by drag & drop, PowerArchiver won’t auto select “ZIP”, but use the last selected archive format, while PowerArchiver already knows, that I’m trying to add files to a ZIP.
      Wishlist
    • Find file in archive.
      Luxor
      Reason I ask is that I was looking for a certain file I knew existed in an archive, but I had to unzip it then use another tool to find the file. It would have saved that extra step if that function existed in PA itself.
      Wishlist
    • Encrypt files inside archive that has already been created [.zipx]
      Hi.
      Is there a way to enable the user to encrypt the files inside a ZIPX archive that has already been created?
      This could save time for large archives that the user may need to encrypt at a later stage or that he/she has forgotten to enable encryption before creating the archive,
      Thank you!
      Wishlist
    • Fast Extract large files directly to target directory
      Hi.
      I would like to see a new feature implemented: a ‘Fast Extract’ Mode.
      Currently PowerArchiver extracts files to a temporary directory and then moves them to the target directory chosen by the user. At least via drag and drop.
      This can be both time consuming and needs free space on the system drive for large files.
      Is there a way to directly extract files to the target directory with PowerArchiver?
      And if not, can a feature like this be considered for future updates?
      Thanks very much!
      Wishlist
    • Serpent-256 Encryption for PAE/PAE2
      Hello.
      I believe it would be useful to implement Serpent-256 encryption for PAE/PAE2 formats, even though PowerArchiver offers strong encryption ciphers already.
      (deleted part advertising other software - admin)
      Do you think this will be a useful addition?
      Thank you for the consideration!
      Wishlist
    • Make portable version compatible with PortableApps
      I think it would be a great option to make the portable version of PowerArchiver compatible with PortableApps (i.e. adding the necessary files and folders to integrate it smoothly into their structure).
      I own various other commercial programmes which -when installed in portable mode- offer to make the becessary changes without needing an extra installer or the official PortableApps repos.
      Thanks for opinions or perhaps even a realization of this.
      A.Borque
      Wishlist
    • PBS Filenames
      Presently, PowerArchiver 2019 (any build) cannot rename PBS filenames by single clicking on such entry or right-click menu has no “Rename” feature!
      Hmm, even pressing F2 on selected entry does nothing :(
      Wishlist
    • pCloud
      B
      Can you add support for pCloud? thanks
      Wishlist
    • ownCloud / Nextcloud
      M
      Please add support for ownCloud / Nextcloud, thanks.
      Wishlist
    • Setting to keep X number of backups
      ghendric
      There needs to be a setting for the backup feature to set how many backup files to keep.
      Wishlist
    • auto open first level in folder treeview when archive is opened
      spwolf
      Wishlist
    • I think SVG files should be treated as text files.
      Brian Gregory
      SVG files (scalable vector graphics) seem to be special XML files and therefore when added to .pa archives I think they should be compressed as if they were text files.
      Wishlist
    • Command Line Switch for View Mode
      BigMike
      I had a look at the command line switches, but there are no switches to change the startup mode.
      At the moment, PowerArchiver opens in the last used mode.
      I’d like to have command line switches to influence the startup mode.
      Basically, the aim is:
      Opening PowerArchiver from Start Menu or Desktop: Start in Explorer Mode Opening PowerArchiver by double clicking an archive: Start PowerArchiver in Archive Mode
      Wishlist
    • move back and forth via prev/next buttons in archive/folders
      spwolf
      OT: A while back I requested that moving up and down in an archive’s folder structure could be considered to work with a mouse’s forward and back buttons like windows explorer does. It is so automatic for me I still try to use them with PA first before realising I have to double-click on the two dots. Can this be done?
      by @drteeth
      Wishlist
    • Different Hash Algorithns
      B
      I know CRC32 was the standard for checking the integrity of compressed files but it is not really used anymore. Can you add ones that are used now MD5 or SHA?
      Wishlist
    • Backups files ordering by NAME as default
      pirrbe
      Opening the ‘Backup’ I still wonder how PA is ordering the files.
      It’s not by name, not by last run…
      Is it not possible to have them ordered by NAME (default).
      Now you have to click on Name to have a meaning overview. If you jump to ‘archive’ and back to ‘backup’, they are again disordered
      Thx.
      Wishlist
    Plugins
    Wishlist
    6494
    • D
      davidsplash last edited by
      why don’t you take a look at this site and use their plugin technology.
      http://www.mimarsinan.com/codextoys.asp
      great way to create sit and even rar files via plugins
      • spwolf
        it will be snowing in june in Europe when David posts his wish by adding it to his previous post he did 10 separate times before :-).
        • D
          davidsplash @spwolf last edited by
          no i was just asking a general question why not join forces and use this codex its not a wish its actually a general question. save time and money developing codexs share them. I have mentioned it before, plugins, but as this is a general question why develop your own plugins that takes a very long time when a proven plugin technology is already avaliable. i was actually trying to speed up development of pa, to keep it head of the game.
          Keep up the work
          • spwolf
            spwolf conexware @davidsplash last edited by
            it is still an wish. And you posted about plugins several times before, in the wishlist forums, now you are posting it in general forums.
            It would look better if you simply update your previous wish, not create multiple posts. This includes all the wishes. Simply search for your post and update it.
            Why would we use some other technology which limits what we can and can not do? Whatever we do, it has to be completly built in and integrated to PowerArchiver, otherwise it will only have fraction of features possible.
            • D
              when will this be?
              i take your point justed wanted to keep you informed. your answer is true to a point, but in past replis on this subject you said you would not do a rar and sit plugin to compress to theses formats thoe the codex i mentioned does. It must be worth investigating rar and sit plugins for pa in the very near future or you might be left behind and i don’t want that to happen as you give the best support around.
              TBGBe 1 Reply Last reply Reply Quote 0
              • TBGBe
                TBGBe @davidsplash last edited by
                @davidsplash:
                … i take your point justed wanted to keep you informed. …
                Yes, but even this “plugin” has been mentioned before :-
                http://www.powerarchiver.com/forums/showthread.php?t=1134
                • D
                  davidsplash @TBGBe last edited by
                  But it keeps it alive if we have a set time scale for the build map of pa then we would not need to keep asking these questions and that would help the developers get on with their jobs
                  • TBGBe
                    The “best way” to keep a topic alive is to add new information to an existing thread.
                    My point is that repeatedly creating new threads for the same topic(s) just appears as “noise” and may cause irritation.
                    • D
                      i agree to a certain extent but it also keeps the idea going enough said about that well will it be implimented as it is sated plugins are already avaliable on the avertise part of this site.
                      • TBGBe
                        @davidsplash…:
                        Where ?
                        All I can find is refence(s) to
                        “PowerArchiver Outlook Plug-in works with Microsoft Outlook 2000, XP and 2003.”
                        • spwolf
                          spwolf conexware @TBGBe last edited by
                          if you search for plugins, posted by david, it is 2 pages worth of results (threads) :-). Wouldnt it be more impressive if it was 2-3 threads with 5-6 pages worth of material? :-).
                          • D
                            i have already said it needs to be tied up and yes in future i will post to old threads if i can fimnd them and if you look at the help file and search for plugins you get pgp plugin thoe you can not get it via the web site yet
