    Wishlist
    Wishlist
    Z
    Wishlist
    PA_FanP
    Wishlist
    Wishlist
    paq9a support
    R
    Wishlist
    Wishlist
    Wishlist
    BigMikeB
    Wishlist
    OneDrive for Business support
    Z
    Wishlist
    BigMikeB
    Wishlist
    Wishlist
    BigMikeB
    Wishlist
    F
    Wishlist
    Wishlist
    Wishlist
    Wishlist
    Folder navigation
    drteethD
    Wishlist
    Quake 1/2 .PAK file support
    AluminumHasteA
    Wishlist
    Find file in archive.
    Wishlist
    Wider dialog window for Add…
    13 Posts 6 Posters 10.7k Views
    • C Offline
      Carlospr
      I’ve installed PA 2006.
      However, the “Add” dialog window could be wider.
      The “Add to archive” text box is small and I always have to press “End” key to go to the end of the line and then change the archive’s name.
      In addition, the text box of the password field could be placed in the “Add” dialog instead of just a button…
      Maybe for this major release, you could make this adjustments to make not only easier but also faster for add with options…
      • K Offline
        klumy
        I agreee with you ;)
        • C Offline
          Carlospr @klumy
          Thanks Klumy!
          I really hope they update the old interface…
          • C Offline
            Carlospr @Carlospr
            Here is my suggestion of a new Add dialog which is just easier (faster) to use:
            • K Offline
              klumy @Carlospr
              Perfect !!!
              • R Offline
                Ricco @klumy
                Very nice!!!
                • K Offline
                  klumy @Ricco
                  the Drag and drop window in beta 3 already has such a design
                  we are just waiting for the add dialog ;)
                  • C Offline
                    Carlospr @klumy
                    It’s really better!
                    But I still think a password field is better then a button. I always use password…
                    PA new after drop window dialog (see my suggestion above):
                      TBGBe @Carlospr
                      @Carlospr:
                      Don’t you need TWO fields - enter and confirm :confused:
                      • C Offline
                        Carlospr @TBGBe
                        Yes, two fields.
                        • B Offline
                          By-Tor @Carlospr
                          I support the idea of making the add box wider instead of having it as long as it is.
                            spwolf conexware @By-Tor
                            i am not sure if we can resize it properly because of the options tab options. we will check it out.
                            • C Offline
                              Carlospr @spwolf
                              With an application like PA the less mouse clicks the better is the user interface!!
                              I use PA everyday for my backups! It’s important to get a fast access to the options.
