<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[More compatibility to Win RAR]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">often i have to install Win RAR just to decompress a *.rar because PA is unable and ends with a CRC Error. Even if the File isn´t defect.</p>
<p dir="auto">I hope this will be fixed soon.</p>
]]></description><link>https://forums.powerarchiver.com/topic/897/more-compatibility-to-win-rar</link><generator>RSS for Node</generator><lastBuildDate>Tue, 09 Jun 2026 08:48:27 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/897.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 07 Jun 2005 09:05:40 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to More compatibility to Win RAR on Wed, 08 Jun 2005 23:39:04 GMT]]></title><description><![CDATA[<p dir="auto">pa relies on the unrar.dll to extract rar files and if that is not kept upto date with the rar specification then it is not there fault for the error. can u tell us what operating sysem memory you have, programs open and the exact process of how you recreated the error.</p>
<p dir="auto">Can you also tell us the size and file names of the files inside the rar and if any different characters are used.</p>
<p dir="auto">Could you post the rar file here which version of rar actually made the rar file, this has been know to be the problem in some cases.</p>
]]></description><link>https://forums.powerarchiver.com/post/8594</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/8594</guid><dc:creator><![CDATA[davidsplash]]></dc:creator><pubDate>Wed, 08 Jun 2005 23:39:04 GMT</pubDate></item><item><title><![CDATA[Reply to More compatibility to Win RAR on Wed, 08 Jun 2005 18:10:43 GMT]]></title><description><![CDATA[<p dir="auto">can you post an example file?</p>
]]></description><link>https://forums.powerarchiver.com/post/8587</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/8587</guid><dc:creator><![CDATA[klumy]]></dc:creator><pubDate>Wed, 08 Jun 2005 18:10:43 GMT</pubDate></item></channel></rss>
